Changed Timing belt, went fine, now belts squeel
Old Jul 13, 2006 | 01:13 PM
Metalluthier's Avatar
Default Changed Timing belt, went fine, now belts squeel
I changed my timing belt and adjusted the valves with my brother and one of my friends on my D16Z6 and after we got it all finished we started it up, and it started up fine no sounds or anything, later when we were test driving it around it started squeeling constantly, so we pulled over and tried to figure out which belt was squeeling, I thought it sounded more like the alternator than anything but it was hard to tell. The belts were still squeeling so we got back in to drive off and the sound stopped. So, I thought it was just an adjustment thing. Well now my car squeels everytime I turn it on, just a quick squeel then it stops, but it happens everytime none-the-less. What the hell is the problem?
Thanks guys
Old Jul 13, 2006 | 01:14 PM
G2 Speed's Avatar
Default Re: Changed Timing belt, went fine, now belts squeel (Metalluthier)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Metalluthier &raquo;</TD></TR><TR><TD CLASS="quote">I changed my timing belt and adjusted the valves with my brother and one of my friends on my D16Z6 and after we got it all finished we started it up, and it started up fine no sounds or anything, later when we were test driving it around it started squeeling constantly, so we pulled over and tried to figure out which belt was squeeling, I thought it sounded more like the alternator than anything but it was hard to tell. The belts were still squeeling so we got back in to drive off and the sound stopped. So, I thought it was just an adjustment thing. Well now my car squeels everytime I turn it on, just a quick squeel then it stops, but it happens everytime none-the-less. What the hell is the problem?
Thanks guys</TD></TR></TABLE>
could be to lose..
Old Jul 13, 2006 | 01:17 PM
PyroProblem's Avatar
Default Re: Changed Timing belt, went fine, now belts squeel (G2 Speed)
one of your accessory belts is loose. Check the tension on them and tighten the one that is the loosest...
Old Jul 13, 2006 | 01:18 PM
Padawan's Avatar
Darth ModerVader
Make sure that the belts and pulleys are clean and properly tensioned.
Old Jul 13, 2006 | 01:19 PM
Default Re: Changed Timing belt, went fine, now belts squeel (Padawan)
THey feel pretty damn tight, I have power steering and the alternator, that's about it for belts, besides timing, but the timing belt shouldn't squeel should it?
Old Jul 13, 2006 | 01:20 PM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Metalluthier &raquo;</TD></TR><TR><TD CLASS="quote">THey feel pretty damn tight, I have power steering and the alternator, that's about it for belts, besides timing, but the timing belt shouldn't squeel should it?</TD></TR></TABLE>
your should hope the timing belt is not lose..., do you have a/c?
Old Jul 13, 2006 | 01:21 PM
Timing belt is normal tension, but if were loose I'd know. I don't have a/c
Old Jul 13, 2006 | 02:22 PM
timing belts wont squeal cause they are cogged(teeth).
How old are the belts? May just need to put a new belt on it?
Old Jul 13, 2006 | 03:03 PM
tampajason's Avatar
Default Re: Changed Timing belt, went fine, now belts squeel (PyroProblem)
The belt is too lose. Torque it correctly to resolve. GL
Old Jul 17, 2006 | 03:25 PM
Default Re: Changed Timing belt, went fine, now belts squeel (sxecrow)
My car has been wobbling at around 60mph and on, do you think the belts would as well add to this? I'm sure they would, I would just like to know, so I can fix everything in one day
And my timing belt is still able to move back and forth on the teeth, uggh
Bolt Thrower - For Victory (1995) - 05 - Graven Image.mp3 [128Kbps] (04:01)
Old Jul 17, 2006 | 03:51 PM
Si_chRis's Avatar
im not sure but doesn't the timing belts on honda's have self adjusters?
Old Jul 17, 2006 | 04:02 PM
Default Re: Changed Timing belt, went fine, now belts squeel (JSpeK_EM1)
Well yea, I know, I'm going to have to take everything apart again and tighten it up. At least the timing belt needs to be tightened, and the Alternator and Power Steering belts need to be loosened
Bolt Thrower - For Victory (1995) - 10 - Armageddon Bound.mp3 [192Kbps] (05:14)
Old Jul 17, 2006 | 04:27 PM
ddd4114's Avatar
The timing belt shouldn't be loose if you installed it correctly (using the tensioner properly), and if it was, I doubt it would squeal. The drive belts might, so check for the tension and for oil, etc.
Also, a belt that is too loose is not good, but a belt that is too tight is even worse.
Old Jul 17, 2006 | 04:32 PM
Default Re: Changed Timing belt, went fine, now belts squeel (ddd4114)
Yea I know, I figured either one is too tight or one is too loose, or both. The timing belt is too loose looking at it, my idiot friends don't know what they're doing, I should have done the tensioner, I was gone...
Old Jul 17, 2006 | 04:36 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Metalluthier &raquo;</TD></TR><TR><TD CLASS="quote">The timing belt is too loose looking at it, my idiot friends don't know what they're doing, I should have done the tensioner, I was gone...</TD></TR></TABLE>
oh god... I'm sorry, man, but I'd never trust any of my friends with my car if I wasn't around. You might even want to rip off the lower timing cover to see what's up. I would, but then again, I'm a paranoid mess with my car.
Old Jul 17, 2006 | 05:12 PM
Syndacate's Avatar
one of ur accessory belts sonds too tight or loose...as everybody's been saying
IN any event...I doubt a squealing sound can be produced by a timing belt..I"ve never heard of it, seen it, and it does not make any sense...
ECStarr
Honda Civic (2001 - 2005)
Aug 30, 2012 04:44 AM
doc500
Apr 13, 2012 05:52 PM
tegsr2o3
Mar 24, 2009 02:03 PM
rpv173
Jul 23, 2005 10:19 PM
Sam268
Sep 20, 2003 10:00 PM
