Honda S2000 Honda S2000
ZEX Kit, nitrous peoples help me out here..
Old Jul 13, 2006 | 12:52 PM
pushinlsteg's Avatar
Default ZEX Kit, nitrous peoples help me out here..
I have a zex kit standing by for me, its got the bottle, the warmer, the lines, the blow down tube, the box for the FPR, TPS, and all that, do I need anything else to run this dry 55 shot safely?
thanks.
Old Jul 13, 2006 | 02:33 PM
iam7head's Avatar
Default Re: ZEX Kit, nitrous peoples help me out here.. (pushinlsteg)
colder plugs?
Old Jul 13, 2006 | 04:48 PM
Kingsta18's Avatar
How does the zex kit work? is it the one with the ECU thingy that reads the A/F before/while spraying to make sure everything is okay?
Old Jul 13, 2006 | 06:44 PM
SuzukaBlueAP2's Avatar
Default Re: ZEX Kit, nitrous peoples help me out here.. (Kingsta18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kingsta18 &raquo;</TD></TR><TR><TD CLASS="quote">How does the zex kit work? is it the one with the ECU thingy that reads the A/F before/while spraying to make sure everything is okay?</TD></TR></TABLE>
I believe it is a "smart" system.
I know it works relative to your throttle position. And it knows when the bottle pressure reaches xx psi it will not engage.
Old Jul 13, 2006 | 07:44 PM
Kingsta18's Avatar
Default Re: ZEX Kit, nitrous peoples help me out here.. (SuzukaBlueAP2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 &raquo;</TD></TR><TR><TD CLASS="quote">
I know it works relative to your throttle position. And it knows when the bottle pressure reaches xx psi it will not engage.</TD></TR></TABLE>
Ah I see. . Thanks for the info
Old Jul 13, 2006 | 08:49 PM
Here's the complete info on the ZEX dry nitrous system for 4 and 6 cylinder engines.
A complete "Dry" nitrous system. Everything is included for a safe, proper installation.
• Designed to work safely on both stock and high-performance, normally aspirated engines. The ideal nitrous system for many fuel injected performance vehicles.
• All major components are factory pre-assembled inside the "Nitrous Management Unit". Easy, plug and play, two-hour installation.
• ZEX Nitrous Systems have an advanced, patented feature called "Active Fuel Control". This feature monitors nitrous bottle pressure and adds or subtracts enrichment fuel. The engine never runs too rich or too lean when engaging the nitrous system.
• ZEX "Dry" nitrous systems activate at wide-open throttle, using advanced electronics that monitor your engine's throttle position sensor. This makes using your nitrous system very easy and reliable.
Old Jul 13, 2006 | 11:44 PM
thanks for the info guys, anybody have a kit or know someone who has had a kit for some time without any problems?
Old Jul 14, 2006 | 05:42 AM
TommyV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pushinlsteg &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info guys, anybody have a kit or know someone who has had a kit for some time without any problems?</TD></TR></TABLE>
I had this on my Civic. It was awesome....... It's quite the rush. I did blow my engine, but there is a good reason, and I don't blame the kit, as I threw a rod, which just indicated that I was making too much power on a stock bottom end.
My advice, subscribe to AAA, because you just never can tell.....
Old Jul 14, 2006 | 10:37 AM
papa5murf's Avatar
please don't install it... it's truely not worth it on the S.....
go direct port or don't do it at all...
Old Jul 14, 2006 | 10:43 AM
PNB's Avatar
PNB
GatorNATION
Default Re: ZEX Kit, nitrous peoples help me out here.. (papa5murf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">please don't install it... it's truely not worth it on the S.....
go direct port or don't do it at all...</TD></TR></TABLE>
I thought that Wet kits were pretty useful on the S?
Old Jul 14, 2006 | 10:51 AM
papa5murf's Avatar
Default Re: ZEX Kit, nitrous peoples help me out here.. (PNB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PNB &raquo;</TD></TR><TR><TD CLASS="quote">
I thought that Wet kits were pretty useful on the S?</TD></TR></TABLE>
you would be correct... but he's using a dry shot.... i don't believe zex offers a wet setup....
as far as i know zex only offers dry setups plugged into your intake tube.... (but i could be wrong, they might have finally evolved and are now offering wet setups?)
Old Jul 14, 2006 | 11:33 AM
PNB's Avatar
PNB
GatorNATION
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">you would be correct... but he's using a dry shot.... i don't believe zex offers a wet setup....
as far as i know zex only offers dry setups plugged into your intake tube.... (but i could be wrong, they might have finally evolved and are now offering wet setups?)</TD></TR></TABLE>
Yep, they now offer Wet kits. I'd link up the kit on their site, but there isn't a direct link (just stays at http://www.zex.com).
4 & 6 Cylinder Nitrous System
Part #82021
A complete "Wet" nitrous system. Everything is included for a safe, proper installation.
ZEX "Wet" nitrous systems activate at wide-open throttle using advanced electronics that monitor your engine's throttle position sensor. This makes using your nitrous system very easy and reliable.
Designed to work safely on stock type engines, but is also engineered to perform flawlessly on highly modified turbocharged and supercharged combinations. The ideal nitrous system for any fuel injected vehicle.
ZEX Nitrous Systems have an advanced, patented feature called "Active Fuel Control". This feature monitors nitrous bottle pressure and adds or subtracts enrichment fuel so the engine never runs too rich, or too lean, when you engage the nitrous system.
Old Jul 14, 2006 | 11:41 AM
papa5murf's Avatar
so they do have a wet setup now... interesting... it's good for the beginner nitrous guy... ....
but like the starter of this thread said.. he's using the dry setup, which i think is a waste.
Old Jul 14, 2006 | 12:03 PM
PNB's Avatar
PNB
GatorNATION
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">so they do have a wet setup now... interesting... it's good for the beginner nitrous guy... ....
but like the starter of this thread said.. he's using the dry setup, which i think is a waste. </TD></TR></TABLE>
I agree.
I would sell the dry and go for the wet or the direct port if you can afford it.
Old Jul 14, 2006 | 03:00 PM
Kingsta18's Avatar
Is there any info on guys that have been running spray? along with how long, and what set up?
Old Jul 14, 2006 | 07:40 PM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kingsta18 &raquo;</TD></TR><TR><TD CLASS="quote">Is there any info on guys that have been running spray? along with how long, and what set up?</TD></TR></TABLE>
if you do it properly you can spray as much as you want....
a buddy of mine had over 100k miles on his car and he was spraying 100shot direct port... had no issues at all...
Old Jul 15, 2006 | 06:53 AM
b18CrxSi91's Avatar
71.179.86.205
They have had wet setups for a while.
A dry 50 shot will give him more torque than hp more than likely and thats just what the s2k needs imo.
leroyb
Jul 20, 2007 09:44 PM
GSR_hatch936
27
Apr 9, 2007 08:27 PM
jman86
Jan 11, 2006 01:30 PM
acuraqc
Feb 5, 2004 04:33 PM
VTECLuDe96
May 23, 2003 09:10 AM
