Idling problems when hose is connected, & idling problems when it isnt! Help!
Old Jul 13, 2006 | 09:54 AM
JCritt's Avatar
Default Idling problems when hose is connected, & idling problems when it isnt! Help!
Hey guys i just got my car back from the shop. The engine was rebuilt with new pistons and a new head. The engine(B18b1) consists of a 95 LS short block and a 99 b20 head.
Now when i got it back, there was no hose that connects from the head (see picture 1 circled in red) to the intake (see picture 2 circled in red)
So i bought a rubber hose from Home Depot and connected these two parts. My engine started to idle around 2k... WHY?
When the rubber hose is NOT connected, my engine idles below 1k and fluctuates back and forth like it WANTS to die.
Can anyone explain/help me fix this problem???
TIA
Old Jul 13, 2006 | 09:56 AM
crx_88_si's Avatar
look around for other hoses that aren't connected. sounds like a vac leak
also, take it back to the shop, they are responsible for getting it to run right.
Old Jul 13, 2006 | 10:01 AM
JCritt's Avatar
Default Re: (crx_88_si)
what should i do about the hose that isnt connected already? leave it?
Old Jul 13, 2006 | 10:30 AM
crx_88_si's Avatar
well how would it be if stock, connected right?
Old Jul 13, 2006 | 10:37 AM
JCritt's Avatar
well when i leave it connected it idles at 2k which is really weird..
Old Jul 13, 2006 | 11:09 AM
Sic_DA_Nine's Avatar
is it only when cold?
Old Jul 13, 2006 | 11:23 AM
JCritt's Avatar
Default Re: (Sic_DC_FOE)
nah it was hot as hell yesterday and it did it also
Old Jul 13, 2006 | 12:43 PM
DC2 Mang's Avatar
Default Re: (DIARRHEA BOY)
sounds like a vacuum leak, or a damaged IACV or FITV, clean those two parts out with carb cleaner
the line you showed in the pictures does not affect idle, it simply recirculates blow by from the head back into the intake manfiold, your car can run perfectly without it
Old Jul 13, 2006 | 01:06 PM
JCritt's Avatar
Default Re: (DC2 Mang)
using photoshop can u indicate where my iacv & fitv is? and simple procedures to cleaning it with carb cleaner?
TIA
John645
21
Aug 18, 2017 05:54 PM
Frost_1097
Jun 5, 2007 10:21 AM
bad brains
Jan 4, 2007 07:40 PM
JCritt
Jul 13, 2006 10:23 AM
98type_r
Mar 17, 2003 12:27 PM
