Looking for a SS lines & fittings list for EG (searched)
I need to order some SS lines and fittings for my eh3 and was wondering if anybody has a list of the fittings used and length of SS line used?..
More specifically, my car is an eh hatchback, and I have a 1" master cyl. I know I need to run a 90 degree fitting for the line that comes out of the MC close to the left shock tower.
I did some searching, and didnt come with anything. So any help or a link to a write up I missed would be great.
Thanks.
Thanks.
Can you be a little more specific as to the function of said stainless steel lines? Are you talking about the SS flexible hose or are you talking about the hard-line that you should be using for brake plumbing? Is there anything else? What kind of fittings and at which other places will you be using this stuff?
We can't help you if we don't understand exactly what you need.
The lines im talking about are the (stock) 2 hard lines that run from the MC to the proportioning valve.
I now have a USDM gsr MC and BB, where neither of the stock hard lines line up. One of the lines on the teg MC comes out from the left (close to the shock tower) and one of the lines comes out from the MC on the right (prop valve side).
Since I do not want to try to bent my stock hard lines so they may (or not) fit, i plan on buying some SS (brake) line and some earls fittings for function as well as the cleaner look.
civexspeedy
Jun 9, 2008 08:54 AM
