coolant drain and refill/flush questions
Old Jul 13, 2006 | 07:20 AM
DIRTYsouthBB6's Avatar
Default coolant drain and refill/flush questions
When the dealership performs a coolant flush on the engine, do they use a flush machine, or do they just drain and fill?
Also, when you drain and refill coolant, is it necessary to drain the coolant from the engine block, or just the radiator?
If a coolant flush machine is used, could someone please explain the process to me?
Old Jul 13, 2006 | 07:54 AM
satsilprelude's Avatar
Default Re: coolant drain and refill/flush questions (DIRTYsouthBB6)
most of the times dealerships do you a machine. from what i understand it will pressurize the system and circulate various cleaners through the radiatior and engine and eventually pulling all the dirt out. i have heard some bad things though about internal components being damaged by the pressure of the cleaning, but that has been in automatics, cant vouch for manual. hope this helps a little. as far as draining the block when flushing by hand i have always assumed that it drains when the radiator is drained, but dont quote me on that.
Old Jul 13, 2006 | 08:32 AM
soundbomber's Avatar
Default Re: coolant drain and refill/flush questions (satsilprelude)
no, only what in the hoses and radiator comes out when you drain the radiator, i believe there's a plug on the block to drain the coolant there.
Old Jul 13, 2006 | 08:38 AM
Default Re: coolant drain and refill/flush questions (soundbomber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">no, only what in the hoses and radiator comes out when you drain the radiator, i believe there's a plug on the block to drain the coolant there.</TD></TR></TABLE>
When the dealership does a cooling system flush, do they remove this plug on the back of the block, or do they just remove the radiator drain ****?
Old Jul 13, 2006 | 08:45 AM
hu's Avatar
hu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRTYsouthBB6 &raquo;</TD></TR><TR><TD CLASS="quote">
When the dealership does a cooling system flush, do they remove this plug on the back of the block, or do they just remove the radiator drain ****?</TD></TR></TABLE>
Where is the plug on the block at??
Old Jul 13, 2006 | 08:46 AM
Default Re: coolant drain and refill/flush questions (hu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu &raquo;</TD></TR><TR><TD CLASS="quote">
Where is the plug on the block at??</TD></TR></TABLE>
I don't know... that's why I'm asking all these questions.
Old Jul 13, 2006 | 09:42 AM
Yield's Avatar
Look at a helms
Theres still some fluid in the block. The bolt is on the back, a bit to the left of the oil filter but there are several bolts there so you need a helms or photo. You can also just put some distilled water in there, run the car up to normal temp and the fan comes on, then drain again.
Old Jul 13, 2006 | 09:51 AM
Default Re: (Yield)
whiteGSR
Jul 26, 2022 03:06 PM
Rvu
Jan 29, 2010 08:15 AM
MrViet
Oct 20, 2009 09:43 PM
LAKER HATER
Nov 24, 2004 07:13 PM
R249
Jan 24, 2003 04:17 AM
