Correct tire size for 90-93 integra?
Old Jul 13, 2006 | 07:12 AM
TurboEM1's Avatar
Default Correct tire size for 90-93 integra?
What is the correct tire size for a 90-93 integra?
195-50-15?
I need a vehicle speed sensor for my 91 crx si with b series engine and i was wondering if i get a 90-93 integra one will it throw off the guage cluster? i am guessing the speedo is calculated from the VSS which is calculated based on tire size.
Thanks
Old Jul 13, 2006 | 07:42 AM
CB7.v2's Avatar
tirerack says 19/55/15.
Old Jul 13, 2006 | 07:44 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Correct tire size for 90-93 integra? (TurboEM1)
All 1990-93 Integras came from the factory with 195/60-14 tires on 14" wheels.
If you get 15" wheels for them, you can use 195/55-15 or 205/50-15. Don't use 195/50-15, which is too small for an Integra, although it's the right size for your CRX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">I need a vehicle speed sensor for my 91 crx si with b series engine and i was wondering if i get a 90-93 integra one will it throw off the guage cluster?</TD></TR></TABLE>
Yes, by 2.1 percent.
Old Jul 13, 2006 | 08:11 AM
TurboEM1's Avatar
Default Re: Correct tire size for 90-93 integra? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">All 1990-93 Integras came from the factory with 195/60-14 tires on 14" wheels.
Now...
The speedo is calculated for a 195-60-14 tire
The chassis is designed for a 185-60-14 tire
I am assuming it is smarter to use a tire that goes with the chassis and just suck it up that the speedo will be off a couple of miles an hour. Right now I have 195-50-15 on the crx but on my next set maybe i will get 205-50-15 to get it closer to both. Will there be rubbing problems on a 205mm tire in a crx? Im only lowered 1.5" maybe 2" the max
Old Jul 13, 2006 | 08:16 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">Will there be rubbing problems on a 205mm tire in a crx? Im only lowered 1.5" maybe 2" the max</TD></TR></TABLE>
Maybe. I would stick with the 195/50-15, and get the correct speed sensor for your car.
Old Jul 13, 2006 | 12:31 PM
Targa250R's Avatar
be professional
You have PM. I don't feel like posting replies in this forum anymore because nsxtasy will probably argue with me over negligible differences for a car that he doesn't own and tires he has never used.
Old Jul 13, 2006 | 01:34 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Correct tire size for 90-93 integra? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">You have PM. I don't feel like posting replies in this forum anymore because nsxtasy will probably argue with me over negligible differences for a car that he doesn't own and tires he has never used.</TD></TR></TABLE>
Wrong, wrong, and wrong. (Just because I don't post a lot about my CRX, doesn't mean I didn't own it for over ten years.) Don't you ever get anything right?
But hey Targa, thanks for all the great information you've previously posted here in this forum...
...oh wait, I was confusing you with someone else. Never mind...
Modified by nsxtasy at 5:50 PM 7/13/2006
JMD
Mar 9, 2006 06:34 PM
LoseRPunKx182
Jan 4, 2006 11:36 AM
Libertariat
Sep 28, 2005 12:32 PM
tweekerz
Sep 15, 2005 05:18 PM
Honduh Chicken
Feb 7, 2005 03:53 PM
