what size hole for a 10 inch sub?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">Every sub is different. One 10" sub may have a 9 3/8" basket diameter, while another may have 9 7/8"... </TD></TR></TABLE>
Hmm Ive never come across that with 12s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">Well since you appear to know it all, then you don't need our help, now do you? </TD></TR></TABLE>
Where does it say I know all?
Anyways problem solved.
And I find it hard to believe that you've never had that problem with 12's... You've never swapped a sub and noticed that the new one fit tighter or moved around in the hole more??? That's because the baskets were different sizes...
You didn't say that you knew it all, but you came across as such.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nuttybumpo »</TD></TR><TR><TD CLASS="quote">Im doing a custion MDF/fiberglass enclosure and dont have the sub yet.</TD></TR></TABLE> Need make and model.
</TD></TR></TABLE> Ditto the above.
Hmm Ive never come across that with 12s.</TD></TR></TABLE> Here are 3 12" JL Audio subs
http://mobile.jlaudio.com/prod..._id=4
http://mobile.jlaudio.com/prod..._id=9
http://mobile.jlaudio.com/prod...id=25
all have diff. mounting dia.
Here are 3 10" JLs...
http://mobile.jlaudio.com/prod..._id=5
http://mobile.jlaudio.com/prod..._id=6
http://mobile.jlaudio.com/prod...id=24
again all with diff. mounting dia.
Not hard to figure out if the same brand of subs use diff. mounting dia. that other brands will also.
94
94
jjzend600rr
Audio / Security / Video
Sep 17, 2007 12:18 PM
