p29 pistons in a z6
Old Jul 13, 2006 | 06:16 AM
donaldmejr's Avatar
Default p29 pistons in a z6
Im planning on putting p29 88-89 integra pistons into my 1995 z6 motor is there any problems with piston to valve clearance??? will use oem head gasket and do a normal mill job before reinstalling the head to block. Does this set up cuase the pistons to hit the valves or and other problems and searched and found differant answers. But nothing straight forward.
Thanks,
Donald
Modified by donaldmejr at 12:08 PM 7/13/2006
Old Jul 13, 2006 | 06:24 AM
spoon92hatch's Avatar
Default Re: p29 pistons in a z6 (donaldmejr)
yes, def clearance issues when vtec engages............and I speak from personal experience.
y8 head
a6 bottem end
Old Jul 13, 2006 | 06:39 AM
d16vtecx's Avatar
Default Re: p29 pistons in a z6 (spoon92hatch)
some have clearance issues: some don't
i advise you tho clay your motor bforehand
Old Jul 13, 2006 | 11:08 AM
donaldmejr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon92hatch &raquo;</TD></TR><TR><TD CLASS="quote">yes, def clearance issues when vtec engages............and I speak from personal experience.
y8 head
a6 bottem end</TD></TR></TABLE>
you said y8 head I heard the same with that head but Im using a z6 head and not going to use the y8 head gasket using a oem z6 head gasket its thicker.
Nichelson_Performance
Feb 3, 2009 10:07 PM
sleepyhamsterlx
Jan 5, 2004 07:02 PM
v4lu3s
May 22, 2003 09:08 AM
Ash J. Williams
Oct 3, 2002 10:56 AM
