high rpm
If your peddle is sticking that would cause it. Pull your air intake tube off and have a look at the throttle body, move the throttle and see if the throttle plate is sticking at all, if it is give it a good cleaning. Also check to see if the throttle adjustment screw has backed itself out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by betonred »</TD></TR><TR><TD CLASS="quote">If your peddle is sticking that would cause it. Pull your air intake tube off and have a look at the throttle body, move the throttle and see if the throttle plate is sticking at all, if it is give it a good cleaning. Also check to see if the throttle adjustment screw has backed itself out.</TD></TR></TABLE>
Well said.
Well said.
frostcivic
Oct 12, 2004 03:52 AM
