Antenna Removal
Old Jul 12, 2006 | 08:26 PM
Duff Beer Man's Avatar
Default Antenna Removal
Welp, i can get my hands on a new antenna however i started to take the old one apart today and i cant figure out how to get the freaking thing out. Do i have to remove the whole motor just to replace the stainless steel part of the antenna? Am i making this to difficult on myself?
Old Jul 13, 2006 | 06:45 AM
94vtecmn's Avatar
Default Re: Antenna Removal (Duff Beer Man)
You need to unscrew the silver part on the outside with a special tool, or carefully with a needle nose plyers. That is a nut that lets the antenna off the body of the car. Most likely the whole unit needs to be replaced.
On a side note, I need one if anybody has one they want to get rid of.
Old Jul 13, 2006 | 08:28 AM
oranginal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94vtecmn &raquo;</TD></TR><TR><TD CLASS="quote">You need to unscrew the silver part on the outside with a special tool, or carefully with a needle nose plyers. That is a nut that lets the antenna off the body of the car. Most likely the whole unit needs to be replaced.
if u use plyers add some tape or use ones with rubber grips. after u get that piece out there is one more nut on the inside of the car trunk. u will have to remove the jack and pull back the trunk carpeting to get to it. then once u unplug the wire connector and antenna signal wire(pulls right out)the whole thing comes out from the inside of the trunk.
Old Jul 13, 2006 | 08:30 AM
oranginal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duff Beer Man &raquo;</TD></TR><TR><TD CLASS="quote">Do i have to remove the whole motor just to replace the stainless steel part of the antenna?</TD></TR></TABLE>
if by stainless steel part of the antenna u just mean the little silver ring then all u have to do is unscrew the old one. if by stainless steel part u mean the actual antenna then i think u would need to take the whole thing out
Old Jul 13, 2006 | 08:54 PM
Default Re: Antenna Removal (oranginal)
Welp i got it out. I have a couple of webpage i could link to if anyone is interested.
Old Jul 16, 2006 | 03:28 PM
demble's Avatar
hi guys, new user in UK here, so hello to you all!
I just bought a '93 si today, and am interested in tidying it up a bit. The aerial has been helpfully snapped off by the previous owner takin the car thru a drive thru carwash!!!! Anyway, any links to websites for advice would be VERY helpful! Thanks again!
Tom
Old Jul 17, 2006 | 05:49 PM
Default Re: Antenna Removal (demble)
These two are the two i found
http://www.antennamastsrus.com...r.htm
http://www.antennamastsrus.com...l.htm
paniaguae640
Jul 27, 2009 08:28 AM
MK Ultra
Dec 6, 2006 08:17 AM
DBAl
Jul 28, 2006 03:19 PM
ng
Dec 19, 2003 07:15 PM
GroundZer0 336
Aug 10, 2003 06:08 PM
