ENGINE SWAP QUESTION
Hey im planning on doing a swap in a eg coupe
engine going in : d16y8
car is a shell right now
who can help me as in wut ill need to do this swap as in everything i need harness etc
so far i got the block, head, tranny , harness, ecu, motor mounts...is there anything else i need?
ive got the dizzy, alt too what else is needed thanks!!!
obd 1 - better for tuning aspect
u will need:
obd1 dist.
obd1 ecu.
and if its from a 96+civic(most likley)then motor mounts too
im sure with a little more searching u will find answers. dont rush it take ur time and make sure u do it rite
u will need:
obd1 dist.
obd1 ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by savinGAShaulinAss »</TD></TR><TR><TD CLASS="quote">obd 1 - better for tuning aspect
u will need:
obd1 dist.
obd1 ecu.
im sure with a little more searching u will find answers. dont rush it take ur time and make sure u do it rite </TD></TR></TABLE>
True to that, and if u have a 95 or lower model chassis (it's ODB1) you'll need a ODB II to ODB I conversion harness (add onto that list)
u will need:
obd1 dist.
obd1 ecu.
yah i have a 92 hatch, doesnt have the engine harness..which one do i get then to swapp in a d16y8 and is there a website i can get it from? also i was wondering .. my friend is gonna give me the stock engine harness that came out of a 92 hatch also can i just use that harness for the d16y8?
i wanna do this swapp as easy as prosible , i seen people do some ghetto re wiring and stuff lol i wanna do it without any ghetto wiring haha thanks
for the wiring u can use ur friends stock wiring harness and add wires for vtec. i forgot what site had this info(ill try to remember)a good site for swaps would be hondaswap.com
It would be alot easier if you stuck with an obd1 motor since it is going into an obd1 chasis. If you absolutely must go with the y8, I suggesst using your existing harness and converting the motor over to obd1. If you really want a thorough explanation pm me.
http://www.phearable.net/chippedecus.html whatever ecu you need
i have a 95 cx hatch and i put in the OBD2 d16y7 with no problems and im running a p08 ecu with the stock cx wiring harness Hasport mounts and an si tranny. should have no problems may have a CEL for a while since some plugs dont plug into the motor from the harness.
civicracer94
Sep 12, 2007 12:16 AM
gohandbz8
14
Feb 21, 2004 05:18 PM
