What Happens to Oil that has Been Sitting?
Old Jul 12, 2006 | 01:43 PM
Flux's Avatar
Default What Happens to Oil that has Been Sitting?
Car has been sitting for several months (say 5) with fresh oil. Car was run only every so often. Heading to the track again and I certainly will change the oil again before I go, but I just got wondering what actually happens to the oil while it sits that long in a car... Does it lose certain properties? Does it degrade?
Old Jul 12, 2006 | 02:03 PM
vtec2nv's Avatar
Default Re: What Happens to Oil that has Been Sitting? (Flux)
hmmm i have no idea...but they sit in containers looong before they get to stores.
Old Jul 12, 2006 | 03:22 PM
Kavehman's Avatar
In containers the oil is sealed from the air.
When its in the block its exposed to the air, so the additives in the oil start to degrade, not only that but im sure your oil has absorbed some water in it too.
Old Jul 12, 2006 | 03:34 PM
white rocket's Avatar
Default Re: (Kavehman)
How many times did you start the car while it was sitting? I've left my car for a month without starting it and I never had a problem.
Old Jul 12, 2006 | 03:36 PM
Kengs's Avatar
I remember seeing a lot of German Castrol in your garage, just change it
Old Jul 12, 2006 | 03:57 PM
P1_Variable's Avatar
I would run some sea foam or motul oil cleaner threw with that oil then change it for new stuff.
Old Jul 12, 2006 | 04:59 PM
Kavehman's Avatar
I don't think any B18C should have any kind of oil cleaners run through them.
Oil changes should just be done frequently, if its done often enough u dont need any of that crap
Old Jul 12, 2006 | 05:29 PM
MK Ultra's Avatar
Default Re:
Most oil degradation is a result of exposure to heat. While the stuff sitting in your crankcase isn't tip-top anymore, I'd wager it's nowhere near as bad as 5-month-old oil would be had the car been used over those 5 months.
Old Jul 12, 2006 | 06:22 PM
ITRbroham's Avatar
shit post warrior
Default Re: Re: (MK Ultra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MK Ultra &raquo;</TD></TR><TR><TD CLASS="quote">Most oil degradation is a result of exposure to heat. While the stuff sitting in your crankcase isn't tip-top anymore, I'd wager it's nowhere near as bad as 5-month-old oil would be had the car been used over those 5 months. </TD></TR></TABLE>
Good point.
Old Jul 12, 2006 | 07:10 PM
Speed Infliction's Avatar
Default Re: Re: (ITRbroham)
my car sat for over a year and a half(long story). I started it up and drove it back to my palce and changed the oil with no problems at all.
Old Jul 13, 2006 | 06:36 AM
Flux's Avatar
Default Re: What Happens to Oil that has Been Sitting? (Kengs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kengs &raquo;</TD></TR><TR><TD CLASS="quote">I remember seeing a lot of German Castrol in your garage, just change it </TD></TR></TABLE>
That's the plan for sure...
Old Jul 13, 2006 | 07:56 AM
Tweakmeister's Avatar
It's fine - I think changing for the track weekend would be overboard.
Old Jul 13, 2006 | 08:19 AM
REDNECK TYPE-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">Car has been sitting for several months (say 5) with fresh oil. Car was run only every so often. Heading to the track again and I certainly will change the oil again before I go, but I just got wondering what actually happens to the oil while it sits that long in a car... Does it lose certain properties? Does it degrade?</TD></TR></TABLE>
When? Where?
Old Jul 13, 2006 | 08:31 AM
SIred91's Avatar
Rainman
Just do what I do. It takes the guesswork out of oil changes.
Take off your filter.
Ship to a lab of your choice.(call your local distributer for that)
It costs about 12 $ to have them analyze it.
And then just run your favorite oil.
I love the Royal Purple 10w40.
I can usualy run around 15,000 miles street, before a needed change.
I can run about 50 hours af hard racing before a needed change.
Just my .02
Old Jul 13, 2006 | 08:48 AM
mullet eater's Avatar
Default Re: What Happens to Oil that has Been Sitting? (SIred91)
When a car sets for a long time the oil draws moisture wich is not good on your bearings. I would change your oil sooner than normal.
ramboPandA
Oct 4, 2013 10:20 PM
Razr2
Oct 29, 2007 09:21 AM
G2_Fella
Aug 19, 2006 01:40 AM
Monkey Fing a Coconut
Nov 9, 2003 07:46 PM
(__________)
Apr 10, 2003 04:07 PM
