couple probs i need help with for my 94 Si please
2 problems im having.
1. my a/c starts up fine blowing cool air, then after about 5 or 10 mins. it totally stops blowing anything at all. same thing when i try the heater. any ideas as to the problem?
2. sometimes when i press in my clutch, theres very little tension and it doesnt even engage. then after a few moments, theres a little more tension and it barely engages. then like, the next day, itll feel totally fine. is my car possessed?
any help you guys could give me is much appreciated. thanks.
about your a/c or fan, i did had the same problem too. for me, it was the fan motor under the dash on the passenger side. somehow, the fan scraps the wall(white container like) then gets stuck on it. you have to knock it a little or take it out and put it back in smoothly. careful because it could spin and scrap the wall causing some smoke by rubbing on it. it could be the wiring too, but just play around with it. sometimes turning the fan on and off back and forth would work too.
about your clutch, i had the same prblem too. like sometimes you will feel only a little pressure on the pedal and shifts hard. all you have to do is bleed the clutch slave cylinder. this is located slightly on the left of your exhaust manifold and has a bleeder sticking out. make sure you check your brake fluids (the small container w/ a floating piece) so it don't run dry. if that doesn't fix the problem then you have a bad clutch masters cylinder or slave cylinder. oh yeah, check and see if you have any leaks around these two parts too.
b16_madman
Nov 15, 2003 04:59 PM
pennies_hatchie
Oct 6, 2003 06:31 PM
