92-95 OBDI ECU REChipping
Honda/Acura Ecu chipping
ECU Chipping/Modification Services
OBD1 ECUs (P05/P06/P28/P30/P72/P75/PR4)
What is done? The Ecu will include one machine 28 pin Ziff socket. One external programming switch, so you are able to switch back and forth between stock or modified code. One external data logging port. All programs are written to 27c256 UV Eraseable Eprom.
Program Mods
- Injector Size/Brand used
- Fuel Pressure at idle (hose off)
- Rev Limiter settings (please specify, dont just say 'stock')
- Launch Control setting if desired
- Idle RPM (OBD1 only)
- VTEC activation RPM (if applicable)
- The stock ECU that came in your car (if it is different than the ECU you are providing
Pricing
Ziff Socket, Data Logging Port, and Program witch And Programmed EPROM (150.00)
Auto to Manual Conversion (OBD1 - $10)
VTEC Conversion for OBD1 P05 or P06 ECUs ($30)
email:sd_ecus@hotmail.com
please but in email header ECU
Modified by dem0nk1d at 4:32 PM 7/12/2006
Program Mods
Pricing
