What Suspension Set up fits for my car
You can get EG coilovers but keep in mind that the Sol is heavier and that means that you won't have the correct spring rates, which means that your car will be a little lower than a civic with the same components.
Nothing to worry about , people do this all the time.
Make sure you get an alignment and set your toe to 0
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjektSol »</TD></TR><TR><TD CLASS="quote">are you saying that the 97 del sol suspension setup is the same for a 92-95 civic?</TD></TR></TABLE>
Yes.
Yes.
Um...well del Sol parts are pretty much specific for the car. The only thing other than engines/suspension that will swap is a civic front lip. The suspension is that of an EG as stated above.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 »</TD></TR><TR><TD CLASS="quote">Do not get EK suspension. The rear shocks are different.</TD></TR></TABLE>
exactly.. the fork at the bottom of the rear shock is smaller and will not fit your lcas
eg and integra can go on an ek (washer spacer) but not the other way around...
what about integras? will the suspension fit?
if so then i believe it will...
as for rear shocks only
integra compatable with eg and visa versa...
ek can use integra and eg, but not the opposite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjektSol »</TD></TR><TR><TD CLASS="quote">are you sure i can use integra coilovers?
because my bro has a 97 integra and i dont wanna go through all the trouble jackin my car up and stuff </TD></TR></TABLE>
you can use integra components. from 94-01.
you can use civic components. from 92-95
you can even use type r as long as you change out the rear control arm and strut.
TRYLSTEG808
Jan 5, 2008 12:11 AM
deadlock32
Mar 2, 2006 07:36 PM
