how do u remove tar off floors help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloS13 »</TD></TR><TR><TD CLASS="quote">dry ice is cleanest and easiest IMHO plus its fun weeeee</TD></TR></TABLE>
Thats what I used. It took about 60lbs worth of the pellets. For the spots that wouldn't break loose with dry ice I used a propane torch and a paint scraper. It's fun to play with a torch, but it doesn't work nearly as well as dry ice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fiji_crx »</TD></TR><TR><TD CLASS="quote">dry ice, wat just leave the ice on top?</TD></TR></TABLE>
Just spread the ice across the tar, and let it sit for 20 minutes or so. When it gets ready to come up you can tell. I just hit the ice with a hammer and it came up easily.
Here are some good links I found by the red Search button in the top right corner. There are more, but you do this too.
Hope this helps!
https://honda-tech.com/zerothread?id=182677
https://honda-tech.com/zerothread?id=355785
Hope this helps!
lucky i live in WI...wait till winter when its below zero...let the tar get nice and hard and pound away with a rubber malet..
Use the dry ice late at night so the temp is already low. Make SOFT taps around with a hammer and it should peel off in big chunks. If you hit too hard you'll dent your floor it's easier to do that than you think. You'll need a heat gun or solvent for the tar that isn't on the floor. Cost me $120 worth of dry ice for my teg, not sure about lbs worth. Goodluck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAallTheWAY »</TD></TR><TR><TD CLASS="quote">I used a propane torch and a paint scraper.</TD></TR></TABLE>
then sprayed wd40 on the floor, rolled the windows up and let the car bake in the sun. Wiped it up with a rag afterwards. Repeat as necessary.
took me 8 hrs and cost $20.
[Eg.6]LiLbOy916
Oct 28, 2006 09:23 AM
Giga Crusher
19
May 6, 2005 11:46 AM
