b18c obd question
Old Jul 12, 2006 | 04:56 AM
novvti's Avatar
Default b18c obd question
Ok i just bought a obd II gsr motor and the guy gave me a obdI ecu, it should work right without any CEL?
Old Jul 12, 2006 | 07:30 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: b18c obd question (novvti)
You know you need a conversion harness right?
Also it depends on what kind of ECU I think and/or if you're missing any sensors.
Old Jul 12, 2006 | 09:13 AM
ek4_b16a's Avatar
Default Re: b18c obd question (SkoundrelUSA)
it depends on which make and model vehicle you have?!
obd1 is 92-95
obd2a is 96-98
obd2b is 99-00
if you have a 92-95 then that swap will work perfectly!
96-98....you'll need the conversion harness for the ecu same for the 99-00
they both are different!!
it won't throw any cel codes unless you have some defective parts on your swap!?!?
gl
Old Jul 12, 2006 | 07:05 PM
ek9-b18cr's Avatar
If you don't have VTEC pressure switch because it's a JDM GSR or ITR, you might want to check out phearable.net and talk to John Vega. Buying a conversion harness needs to be altered a little.
maxwellmercer
Mar 11, 2011 10:08 AM
EvasiveMotorsports.com
Performance
17
Oct 30, 2009 02:51 PM
Happy Gilmore
Jun 12, 2008 05:33 AM
PY01ITR42
Jul 12, 2002 10:37 PM
