No Start Problem
Old Jul 11, 2006 | 11:26 PM
INCNTRL4's Avatar
Default No Start Problem
Alright heres the deal, I just finished swapping a new motor into my car, I installed a walbro 255, and the normal stuff you'd do for a turbo application.
Go to start it up tonite, and the fuel pump wont even engage (problem number one)
who knows if anything else is wrong, anyone have any ideas, i checked the plug on the pump and its good.
any help would be awesome
Old Jul 12, 2006 | 03:48 AM
antivic's Avatar
Default Re: No Start Problem (INCNTRL4)
did you install the pump itself right? did you ground it out? is it plugged in..?checked all your fuses?
Old Jul 12, 2006 | 06:03 AM
INCNTRL4's Avatar
Default Re: No Start Problem (antivic)
yeah i believe its done right, which wire do i groud out (double checking cant think off hand which one i did) and im checking fuses tonite, was too tired and stressed to check everything last night.
any other options?
Old Jul 12, 2006 | 07:24 AM
NoLongerNA's Avatar
The only other thing that really could have happened that wouldnt allow your fuel pump to kick in is your ECU would be fried. But I dont think that is your problem. So if I were you I would check, double check and then check again! Im sure you'll find the problem.
Old Jul 12, 2006 | 07:32 AM
BuddhaSiR's Avatar
Default Re: (NoLongerNA)
Check to see if you have voltage going to the fuel pump. check for a ground. When you turn the key on, pump will run for a couple seconds then turn off. If you have voltage and ground, pump should run.
Old Jul 12, 2006 | 03:46 PM
INCNTRL4's Avatar
Default Re: (BuddhaSiR)
it doesnt even start to power up, cant even hear it, even with the cover off it and everything!
Old Jul 12, 2006 | 04:53 PM
mmuller's Avatar
Mad Scientist
Default Re: (INCNTRL4)
because you cant hear the pump prime it does not mean its not getting 12v.
-check voltage to the pump
-if the pump is not getting 12 when ig. on, then check you main relay and power to the main relay.
does you check engine light come on when you fisrt turn the key on?
Old Jul 12, 2006 | 05:36 PM
INCNTRL4's Avatar
Default Re: (mmuller)
yeah its throwing the code for oxygen sensor (because i have my wideband sensor where the O2 normally is) and for vtec (because i need to finish the connection of the wife.
Old Jul 12, 2006 | 07:12 PM
INCNTRL4's Avatar
well i check it, no power is running to it, now checking all the fuses for a bad link
Old Jul 26, 2006 | 09:18 AM
BuddhaSiR's Avatar
you need to check the Main Relay. Voltage to the pump comes from that relay.
dc4teg95
Aug 25, 2012 05:31 PM
cueto
Jun 15, 2009 07:37 AM
ludelover88
Jun 23, 2008 09:04 AM
deckster333
Sep 10, 2006 10:43 AM
ninetyfourgsr
Jul 3, 2002 11:21 PM
