help: car bogs after changing distributor
Old Jul 11, 2006 | 10:58 PM
rhdjdmda6's Avatar
Default help: car bogs after changing distributor
well here it goes, i changed the spark plugs and gapped them, changed the wires, distributor was bad so i got a rebuilt one from a autoparts store, new cap and rotor, checked timing on crank is correct, could it be the distributor timing? i tried to put it on the middle, then messed with it to advance and retard both still bogs, bogs at around 3000 rpms, im getting a cel code of 9, which is the nbr 1 cyl sensor? i dont understand why. oh here are my specs.
94 civic si
d16z6 bone stock just intake
new plugs
new wires
new cap
new rotor
new distributor
could it be the timing? or i just got a bad distributor? any help is appreaciated thx!
Old Jul 12, 2006 | 12:58 AM
fms1day's Avatar
Default Re: help: car bogs after changing distributor (rhdjdmda6)
I would say check timing first... then diagnose the distributor or bring it back for to the autostore for a switch... (try to do this within a few days [from purchase to exchance] since most stores are ******** about it)
Old Jul 12, 2006 | 01:09 AM
KloC 95 EG's Avatar
Default Re: help: car bogs after changing distributor (fms1day)
checc timing
Old Jul 12, 2006 | 02:48 AM
Slamaccord's Avatar
Default Re: help: car bogs after changing distributor (KloC 95 EG)
Get yourself a timing light or gun whatever you want to call it.
Tinkering with the distributor positions is not the proper way to set base timing.
I got money on that the timing off.
Unless you got a defective distributor.
Old Jul 12, 2006 | 03:28 AM
slowSOHCvtec's Avatar
Default Re: help: car bogs after changing distributor (Slamaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slamaccord &raquo;</TD></TR><TR><TD CLASS="quote">Get yourself a timing light or gun whatever you want to call it.
Unless you got a defective distributor.</TD></TR></TABLE>
yeah use a timing light and check your timing, plenty of info if you search ignition timing...your rebuilt dizzy might be a bum, but check timing first
Old Jul 13, 2006 | 04:52 AM
rhdjdmda6's Avatar
ok i tried 3 refurbished distributors already, timing is on the mark i used a timing gun of course. but i solved the problem i found someone with a used oem distributor works perrrrrrfeccct. i was almost running out of choices i checked everything from map, to tps,to vacuum lines. but the autoparts store told me there are two types a hitachi and tec. well i think they gave me a hitachi when mines was tec i dont know that is the difference but thx for your help guys im so happy to be driving my car again .. wait i still need help .. there are marks on the crank pully i know white is 0BTDC but what is red???
honda_crv_2000
Honda CR-V & Element
Jan 16, 2015 01:14 PM
96a-ccord
Feb 26, 2010 02:04 PM
meallout
Mar 19, 2009 11:34 AM
civicboisi
Oct 4, 2004 08:27 AM
90_crx_si
Mar 23, 2004 03:58 PM
