question about white smoke
Old Jul 11, 2006 | 09:34 PM
slipperyduck's Avatar
Default question about white smoke
i just want to know what white smoke is from. i have a dx head with a si cam and trying to figure out if that could cause the smoke. it only smokes like in 2nd gear when im on the gas but it smells like feul and not water. tried timing it 3 times and still no answer but also has a bubbling from the exhaust. if anyone could help email at taz1031500@aol.com or reply
Old Jul 11, 2006 | 09:59 PM
elrandeeto's Avatar
Default Re: question about white smoke (slipperyduck)
usaully white smoke is antifreeze and it will smell sweet and is usaully a sign of a blown headgasket . ( it will run rough also )
condensation will come out white , but usaully not just when your on it .
you said it smells like gas usaully gas is black smoke oil is blue .
ok im kinda guessing here but i think there might be a chance your cat is fuked up
Old Jul 13, 2006 | 03:23 PM
Default Re: question about white smoke (elrandeeto)
no cat on it but i just changed the head gasket and smokes like a$$ but does have a little black i just noticed today coming out and some back fire .. does not run real bad just sometimes when its cold it staggers a little bit. i have power and all. i just read on here that if i had a si cam that it would be a half tooth off. but ok
Old Jul 17, 2006 | 08:13 PM
ok no one damn .. need help bad
Old Jul 17, 2006 | 09:14 PM
Suck my DX's Avatar
are u sure you used the right head gasket?
Old Jul 22, 2006 | 02:55 PM
Default Re: (Suck my DX)
yeah i think the head might be warped and/or the head bolts might be stretched
Old Jul 22, 2006 | 03:00 PM
xx89civicracer89xx's Avatar
Default Re: (slipperyduck)
or maby its just ur using a SI cam in a dx wich would have more lift wich means more air/fuel will come in (ur runnin rich) and that u have NO cat...with NO cat ur car wont try to burn the air comin out and there for it will just come out ur exhaust... i have the same prob with my DOHC ZC i have straight pipin no cat and if i down **** all the way then stop my car will smoke like hell but if i just coast and then brake it doesnt smoke... but if i get on it it smokes...
2kdrift
15
Feb 26, 2017 05:58 AM
thedon360
Jul 16, 2013 08:34 AM
mafia
Aug 17, 2007 05:58 PM
Skinflute22
10
Aug 2, 2005 07:49 PM
R-1303
Nov 26, 2002 01:41 AM
