94 cx will not start wtf?
Old Jul 11, 2006 | 08:46 PM
TheCheeseWedge's Avatar
Default 94 cx will not start wtf?
im posting this for a friend.
He was driving his 94 cx civic hatch (the motor is stock except for an LS TB the previous owner put on) and the distributer blew out on him, the car sputtered to a stop and would not start. we replaced it with another known good 94 cx distributer along with new plugs, and wires. the motor will turn over fine but still will not start. i noticed that when the key is on the "on" position the fuel pump does it cycle and after its done pressurizing there is a buzzing sound coming from all 4 injectors, and there is a smell of gas (seems like the injectors are stuck open some how). Does the main relay control igntion on these civics, like it does on the older accords? Could it be a possible fuse?
Checked:
-Grounds
-Timing belt for damage or loosness
-No check engine light
-No fuel in the cylinders
-Good battery
any other suggestions because im stumped?
Thanks
Old Jul 11, 2006 | 09:53 PM
project_delta's Avatar
Default Re: 94 cx will not start wtf? (TheCheeseWedge)
Could be the main relay, but if you hear your fuel pump running, then it's probably not the relay. Did the old distributor sieze up? If it did, your timing belt may have skipped a few teeth when it did, though it may now appear to be fine. Make sure your timing marks line up proper. This happened to a friend of mine a while back. If that's all good, check for spark. If your timing belt was off by a few teeth, then get it lined up again and do a compression test. Just remember, your engine needs three things to work, spark, fuel, and compression.
Old Jul 11, 2006 | 10:10 PM
streetracerjoey210's Avatar
does car read a a/c voltage at tach, to test get a volt meter and locate dead end wire... it is on driver side fender well by brake resiover, some times it wrap in blue tape, attach red probe to grey plug and black probe to car chasis (ground) then set voltage meter to a/c.. and look for reading.. 02.6.0 vts.. when cranking over
tach wire should have some power to as engine rev's higher volt's read higher, if no voltage then coil could be bad,,, had same problem
Honda squadvic
Jul 3, 2017 10:33 AM
Culinarydolly
May 27, 2014 08:07 AM
94hatch_man24
Aug 2, 2011 12:50 PM
crispy93
42
Sep 9, 2009 02:28 PM
deepdownpaul
Aug 22, 2009 10:42 AM
