searched , started to have idle prob's , help asap !
I was on my way home from work tonight and pulled into a gas station and when I went to leave I started my crx and it jumps from 500 to 1000k rpm repededly.
I searched for a few minutes but really need help soon on this one boys , i've got to go to work in the morning and hate driving it if it seems to have a issue !
Help a cracker out !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luelf21 »</TD></TR><TR><TD CLASS="quote">adjust the tps. Also, your IAVC or FITV might be bad, or maybe you have air in your coolant lines.</TD></TR></TABLE>
I'm going to try and clean out the IACV in the morning but i'm unsure what a FITV is , I had a whistle niose problem last month and adjusted the throttle screw and it went away and idled much better , is it possible for the screw to back out on its own that soon ? it was very easy to turn. Thanks for the help guys , this site rocks !
its very possible for the screw to back out....i mean anything is possible, but i dont believe it is your throttle position screw messing with your idle.
Clean the screen on the IAVC like you were going to do.......see if that fixes it.
FITV= Fast Idle Thermal Valve. Its on the bottom of your IM. Sometimes ascrew on the inside backs out and causes it to idle funny, and sometimes the FITV just is plain ol' bad and needs replaced. That goes for the IAVC also. There are several ways to scheck to see what is actually wrong so if you want to know, just pm me and i will explain them to you. Personally, i think your IAVC is causing it.
Well its running smooth again !
I pulled another IACV off one of my spare intake mani's out in the shop and swapped them out . Then started the car and let it warm up and it idled back down like normal.
Thanks again for the help guys
Later,
Later,
RevenantEJ1
Oct 27, 2008 03:16 PM
CHAMPwhteEK
10
Jan 8, 2008 10:24 AM
