using stock motor mounts for b16
Old Jul 11, 2006 | 06:21 PM
myEK=slow's Avatar
Default using stock motor mounts for b16
im about to purchase a b16a2 and i have a 97 DX hatch... i was looking on the hasport website and all i saw were replacement mounts for a 96-00... so do my d series mounts work for a b16.? thanks in advance.... matt
Old Jul 11, 2006 | 06:48 PM
ekb16's Avatar
99-00 Si driver side motor mount bracket
99-00 Si Rear "L" bracket
the rest of the mounts and brackets will work
Old Jul 11, 2006 | 06:56 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">99-00 Si driver side motor mount bracket
the rest of the mounts and brackets will work</TD></TR></TABLE>
yup
but the hasport mounts are bad ***. if you have the coin, throw down.
Old Jul 11, 2006 | 07:57 PM
myEK=slow's Avatar
psh... no coins here... ha just some pocket lint after i pick up this motor... so i need to buy too mounts.. thanks guys.
Old Jul 11, 2006 | 08:01 PM
myEK=slow's Avatar
about the driver side are u tlaking bout the actual mount or the braket that bolts to the block?
Old Jul 11, 2006 | 08:05 PM
Mr. Badwrench
Default Re: (myEK=slow)
leave the thing bolted to the fenderwell, you use the bracket you have, you need the bracket with the 3 bolts under the timming cover.
Old Jul 11, 2006 | 09:36 PM
myEK=slow's Avatar
nvm guys just managed to snag a full set of SI mounts for 50 bucks...
Old Jul 11, 2006 | 11:26 PM
Groove_D's Avatar
How about b16 first gen? You use the same mounts as specified earlier?
Old Jul 12, 2006 | 11:17 AM
myEK=slow's Avatar
one more question.... will i have to get an obd2A to obd2b conversion harness... like for the dash? my friend brought it up and confused the hell out of me.
Old Jul 12, 2006 | 02:01 PM
ek4_b16a's Avatar
just forget the mounts...get an aftermarket driver side upper mount from like avid or innovative...works just like hasports...just cheaper in price. looks nice too! also stronger than the 96-00 civic driver side upper mount.
take a t-bracket from a 96 del sol dohc vtec or a 99-00 si
if you are going to use the 99-00 si ecu, you will need to get a conversion harness for your obd2a to the ecus harness which is obd2b. but if you want, it would be better to just get an obd1 ecu and the conversion harness...makes everything easier...i'm using a conversion harness to run my obd1 ecu in my obd2a vehicle harness
and about the confusion...
obd2a is for the 96-98 civics and obd2b is for the 99-00 civics no matter what model it is...
you can not use a 99-00 ecu in a 96-98 civic unless you have the harness visa versa...
but if you could get an obd1 ecu...it'd be better...
good luck with your swap...
Old Jul 12, 2006 | 03:11 PM
daoryder's Avatar
Default Re: using stock motor mounts for b16 (myEK=slow)
http://i7.photobucket.com/albu...1.jpg
Old Jul 12, 2006 | 03:12 PM
myEK=slow's Avatar
okay, than do i get a p75? or do i jsut chip a p28 and make my own map?
Old Jul 13, 2006 | 11:51 AM
wespirl's Avatar
1) P75 won't work... u need a vtec ecu... unless u don't want vtec.
2) ur DX wiring harness doesn't have the vtec wiring so you'll either have to wire it in (3 wires) or get an ex harness
3) conversion harness will depend on what ecu u're going to run
Here's a pretty good write up: http://www.phear7imports.net/trey/6gen/
Old Jul 13, 2006 | 09:45 PM
myEK=slow's Avatar
oh yeah... my p75 was in my b18coupe.. duhh... thanks man.
knappy03
Jul 28, 2011 12:49 PM
EM1 Resto
Sep 24, 2009 01:28 PM
corkss
Sep 11, 2008 11:25 AM
jdmcivicb16
Feb 5, 2004 09:24 PM
jpcivic
Dec 29, 2003 05:52 AM
