Vacuum Lines
I looked at a vacuum line diagram for a H22 and it showed that the nipple that is blocked off in this pic had a line connecting it to the EVAP purge control diaphragm valve. Where is that? I don't see a EVAP canister or control valve at all...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Missing Gears »</TD></TR><TR><TD CLASS="quote">the evap canister/valve is on the car, and you normally use a smaller vaccum port to run to the canister.</TD></TR></TABLE>
the diagram i was referring to was the picture found in this post: https://honda-tech.com/zerothread?id=933645 Where exactly is the evap canister? I don't see it...
Actually, the nipple you see in the lower left hand corner of the picture coming off the throttle body is also showed to have a line going to the EVAP purge control diaphragm valve in the diagram, but i don't know where that is...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR »</TD></TR><TR><TD CLASS="quote">it's located underneath where the stock intake is,
near the battery.
a little box maybe 4" X 3"</TD></TR></TABLE>
eh...can't find it...Am I just retarded or what...? Or is this a piece that could have possibly been deleted with the swap?
near the battery.
couldve been deleted, it should be right below the fuel filter on the firewall, its about 4 inches in diameter, and maybe 7 inches long.
Kaspk
Apr 6, 2007 03:12 PM
invisible
Mar 13, 2007 10:35 AM
Tyson
18
Nov 4, 2003 05:41 PM
