Running rough
Old Jul 11, 2006 | 04:39 PM
jdmKIDinEF's Avatar
Default Running rough
88 hatch. In the morning it runs fine when it warms up it boggs and the idle is up and down sometimes it wants to shut off but i keep reving it so it doesnt. the ecu is reading number 17 the speed sensor. Help! what can I do to make it last until my swap.. It stock sohc. Thanks guys.
Old Jul 11, 2006 | 04:49 PM
jdmcrx90's Avatar
try turning up your idle screw when your car is warmed up and set the idle at about 750-800 also try cleaning out your idle air control valve it on the back of the intake manifold
Old Jul 11, 2006 | 04:54 PM
Suck my DX's Avatar
Default Re: (jdmcrx90)
sounds like an iac issue..make sure its connected and not clogged..
its possible the speedo cable popped outta place...check that out as well
jdmKIDinEF's Avatar
good stuff Ima do that, reset my timming and new spark plugs.
Old Jul 11, 2006 | 04:55 PM
jdmKIDinEF's Avatar
Default Re: (jdmKIDinEF)
were can I find that cable?
Old Jul 11, 2006 | 05:04 PM
Suck my DX's Avatar
it runs from the back of the cluster to the top rear of the transmission...
ONECLEAN91
Mar 16, 2011 04:58 AM
Lethal001
25
Jun 16, 2008 04:49 PM
thecorey
12
Dec 26, 2007 07:36 AM
PINKS
May 29, 2006 10:26 PM
sporkcrx
Nov 9, 2002 06:59 PM
