What is wrong with my car??? Dynoed today
Hows it going? Im a little pissed off right now due to my dyno runs which are much lower than I had expected. I do not know what the problem is, but here is my setup and tuning:
Mugen ECU
Mugen header
Iceman intake
tanabe RM cat back
ctr pistons
ctr cams
mugen thin head gasket
jun springs and retainers
vafc
here are the vafc settings:
wide hvt:
4000 +20
4500 +25
5000 +24
5500 +21
6000 +19
7000 +16
8000 +13
9000 +11
Lvt
1000 +7
2000 +9
3000 +17
4000 +22
5000 +20
5500 +20
6000 +18
6500 +18
narrow are all set at 0
v/t unmt hi<<l +50
v/t unmt lo<<hi 0
throttle
lo 35%
hi 60%
nep hvt
4000
4500
5000
5500
6000
7000
8000
9000
nep lvt
1000
2000
3000
4000
5000
5500
6000
6500
my ignition timing is at 12, he said when he set to 17 or 18 it would knock too much
every run i hade was withing a hp or so, heres the 3 runs:
1st: 170.7/127.9
2nd: 168.0/126.1
3rd: 169.1/126.6
you can see why im angry, please help me determine whats going on here thanks in advance
Mugen ECU
Mugen header
Iceman intake
tanabe RM cat back
ctr pistons
ctr cams
vafc
wide hvt:
4000 +20
4500 +25
5000 +24
5500 +21
6000 +19
7000 +16
8000 +13
9000 +11
Lvt
1000 +7
2000 +9
3000 +17
4000 +22
5000 +20
5500 +20
6000 +18
6500 +18
v/t unmt hi<<l +50
v/t unmt lo<<hi 0
throttle
lo 35%
hi 60%
nep hvt
4000
4500
5000
5500
6000
7000
8000
9000
nep lvt
1000
2000
3000
4000
5000
5500
6000
6500
1st: 170.7/127.9
2nd: 168.0/126.1
3rd: 169.1/126.6
also, he said my map sensor was bad and replaced it but it made no difference. This guy also said that stock itrs make 165 crank and another itr was coming in later with toda cs that makes 202 at the wheels with 350 runs on it.......i still have a check engine light code 3, had it before, still have it now
No adjustable cams gears? That would help a lot towards tuning.
Plus, I would make sure everything else is set up right.
a little background, evidently the previous owner 'detuned' the car to keep casey (typeRforwhenIB18) safe or some horseshit. rumor has it the guy dyno'd somewhere in VA and hit 200+whp.
[Modified by Brian Spilner 1035, 1:55 PM 4/20/2002]
Did you tune the V-AFC on the dyno with a wideband O2 sensor? I ask cause those VAFC setting seem to be pumping in a lot of fuel...most people if anything seem to try to put LESS fuel in the 7K and up area. But maybe your mugen ECU makes your situation different???
it was tuned with an 02 sensor...i have no idea on the mugen ecu, ive heard a lot of bad things about it but ep runs one in his car and he makes 208/146
advance the timing. 12 is way too low. i was running 12:1 compression before with 17 degrees timing. get some cam gears too, because this is where the hp will come from
also why are you running jun springs ?? do you plan to upgrade to jun cams later ??
they were installed by previous owner as a precaution seeing the mugen ecu raises the rev limit to 9100, but jun3s are a possibility in the future if i get rid of the ecu
getting cam gears, but dont have them yet
weak sauce=the shitty gas i have in it...knocked since i got it filled up
cam gears will definitely help. They'll give ya a bunch in the midrange maybe a few up top. You need to look at your air fuel ratio. What do your spark plugs look like? When all tuned in you should putting down 190/131 somewhere around there, with a nice midrange. Try putting your timing at 15. 17/18 might be too much for the compression you have. The potential power is there. On my car I was pulling a map sensor code and it wasn't the map sensor. It turned out to be the wiring on the vafc , you may want to check into that. In my case the wires came uncrimped.
Sorry about the numbers Casey, hope you get it sorted, i know that motor is capable of so much more.
Can't recommend anything, i don't know anything about fine-tuning honda motors!
your vtec is coming on too low, look how the lobe jsut bogs, increase taht at least by another 200rpms. your airfule is wack, it looks like you have some kind of problem up high. id increase the timing till you hear it start to knock, tehn back it off.
[Modified by b20bastard, 1:14 PM 4/20/2002]
nah i listed that in my mods, but yeah it looks fugged up in high rpm, thanks alex i know it does too
[Modified by TypeRformewhenIB18, 9:17 PM 4/20/2002]
you do know that with that CEL puts your car in limp mode. Its making it extra rich. your engine is probably drowning. I don't see where your graph is posted to look at.
it was a code 3 btw, just got it turned off, by disconnecting the battery for 10 minutes uggh, he wouldnt listen to me at the dyno when i said to do it, he just disconnected some wire that turned off my radio and clock for 30 seconds
so basically, i need to:
get my fpr on(will be here monday)
get some cam gears(jdmhp look best for money so far)
get some bigger injectors(maybe)
get a real tuner(coughcoughjackcoughcough
