Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
need help picking a proportioning valve for a eg8
Old Jul 11, 2006 | 01:46 PM
aarontrini85's Avatar
Default need help picking a proportioning valve for a eg8
we are in the proccess of building a turbo d in a eg8 and i need a little help with the brake system
it is currently stock up front with hawk pads and rotors
and the rear is all gsr i was woundering what proportioning valve u guys have had the best luck with on a setup like this
if it makes a diffrance the rest of the suspension is gsr front sway with gsr lca's
the rear is type r sway with function 7 endlinks and asr rear subframe brace
and omni coilovers
any advice would be apreciated thank you
Old Jul 11, 2006 | 02:14 PM
RPM_69's Avatar
Default Re: need help picking a proportioning valve for a eg8 (aarontrini85)
Jegs sells Wilwood adjustable proportioning valves for $40.
Old Jul 11, 2006 | 03:29 PM
Default Re: need help picking a proportioning valve for a eg8 (RPM_69)
i was looking to go more with like a stock gsr one or type r but hell that is a good price but ill have to play around with it to tune it but then again i like to learn so ill probly get that
do you know of any guides for helping with adjusting it??
Old Jul 11, 2006 | 05:23 PM
bosco500's Avatar
The only way I have found the wilwood adj prop valve to work, is to run equal length lines to the fronts, then run a single line back to the driver where the prop valve is installed. Then go from the prop valve to a tee, then to the rear calipers. Be careful though, the front lines have to be equal in length, as do the rears. I found out the hard way.
If I had it to do over again, I would have stuck with the 40/40.
Old Jul 11, 2006 | 06:22 PM
Tyson's Avatar
Default Re: need help picking a proportioning valve for a eg8 (bosco500)
its 4040. not jay-z's 40/40 club. there is no goddam /.
Old Jul 12, 2006 | 05:16 AM
bosco500's Avatar
Default Re: need help picking a proportioning valve for a eg8 (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">its 4040. not jay-z's 40/40 club. there is no goddam /.</TD></TR></TABLE>
sorry, im not the prop valve master.
Old Jul 12, 2006 | 10:56 AM
Stinkycheezmonky's Avatar
Suspetise...
I think Tyson's a little peeved at all the people who think it's 40% Front / 40% Rear split or something
Old Jul 12, 2006 | 11:55 AM
bosco500's Avatar
Default Re: need help picking a proportioning valve for a eg8 (sscguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy &raquo;</TD></TR><TR><TD CLASS="quote">I think Tyson's a little peeved at all the people who think it's 40% Front / 40% Rear split or something </TD></TR></TABLE>
Well duh. The other 20% goes to the intercooler.
Old Jul 12, 2006 | 11:59 AM
Tyson's Avatar
its just not correct and as you pointed out, makes no sense.
Old Jul 12, 2006 | 01:26 PM
Suspetise...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bosco500 &raquo;</TD></TR><TR><TD CLASS="quote">Well duh. The other 20% goes to the intercooler.</TD></TR></TABLE>
LOL!!!!
coneheadsracing
17
Jan 23, 2006 06:34 PM
kreush33
Oct 7, 2002 11:21 AM
