knock sensor for 95 h22a1 - can i use one from any other engine/year/model??
Old Jul 11, 2006 | 12:45 PM
oranginal's Avatar
Default knock sensor for 95 h22a1 - can i use one from any other engine/year/model??
i need a knock sensor, i put this in the want to buy thread also.
do i need one from a 95?
what years/models/engines can i use the knock sensor from?
and if any1 knows a good site /place to get one from that would help also.
would this work??
http://cgi.ebay.com/ebaymotors...ZWDVW
thanks
Old Jul 11, 2006 | 12:49 PM
bb_one's Avatar
Default Re: knock sensor for 95 h22a1 - can i use one from any other engine/year/model?? (oranginal)
Yes any honda KS will work. They are all the same, you MUST check that the connector plug is similar however.
There are 2 types of KS, one with a circle plug and one with a square plug. Obviously if you have a circle one a square one would not work.
Old Jul 11, 2006 | 07:37 PM
TruNinja619's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oranginal &raquo;</TD></TR><TR><TD CLASS="quote">i need a knock sensor, i put this in the want to buy thread also.
would this work??
thanks</TD></TR></TABLE>
yea.. that one should work...
I remember paying about $160 for my knock sensor... I was just tired of seeing my check engine light going on after the car was warmed up... and plus I had to smog my car.. lol
if you get a knock sensor.... it should be the one that uses a one wire connector... the 96-on knock sensors uses 2 wires... and I believe the other wire is used a reference voltage for the ECU...
Hatch_Back_97
Apr 4, 2011 01:31 AM
mannydhanju
Jun 21, 2009 08:55 PM
integg93
Aug 3, 2006 01:17 PM
Leviata-N
Mar 13, 2006 11:36 AM
