i really did help (TPS) ?????????????????
Old Jul 11, 2006 | 11:51 AM
dkrex001's Avatar
Default i really did help (TPS) ?????????????????
what tps can i use for a 92 b18a1 and how can i test it and what is it suppost to read.
Old Jul 11, 2006 | 12:10 PM
RHDintegXsi's Avatar
Default Re: i really did help (TPS) ????????????????? (dkrex001)
you can use any b series tps sensor..maybe even some single cams but dont quote me on that..
to test/adjust it you need an volt meter. test the voltage of the signal wire while the ignition is in the on position but engine not running..it should be the middle (red/black) wire. at idle should be around .5v and wide open throttle around 4.5v
Old Jul 11, 2006 | 01:30 PM
dkrex001's Avatar
Default Re: i really did help (SINFULintegXsi)
thanks man
LaMaravilla
Sep 18, 2010 12:28 AM
MJT805
Jun 12, 2009 11:05 AM
1993-eg1
Mar 19, 2009 05:25 PM
Powered by VTEC
Jan 30, 2008 10:06 AM
dmxsoulja3
Dec 16, 2004 05:56 PM
