Install Tower Bar without change the short ram?
I'm just a newbie here, and want to ask some questions, hope you guys can give me some clues.
I'm having a 96 Civic 4 doors with D engine. I want to install a tower bar under the hood, but the Intake just blocks in between. Does anybody knows if there any tower bar fits to it without installing a new short ram?
Thanks alot!
Thanks alot!
Welcome to H-T.
As far as the strut bar goes you should be able to install it without changing anything in you engine compartment. What kind is it?
I found the pic of my engine, please have a look
http://www.cardomain.com/ride/795800
If anyone knows, please let me know....thx thx thx
Modified by xelloss at 1:45 PM 7/11/2006
the way the intake comes up and to the right, there arent many strut bars that will work, because they will rub on the intake. most are designed for the b series motor swapped in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai »</TD></TR><TR><TD CLASS="quote">the way the intake comes up and to the right, there arent many strut bars that will work, because they will rub on the intake. most are designed for the b series motor swapped in.</TD></TR></TABLE>
not true... a y8, z6, or even the old civic si (ef hatchback) manifolds are not b series manifolds and they allow strut bars to fit..
strut bars are not designed to meet the needs of a motor, they are deisgned to rigidly anchor two points (shock towers in this case together).
the reason he is having trouble is because he has the weird intake manifold where the intake connects vertically not horizontally.
from experience... there is not much you can do.. but if you get a y8 manifold.. i hear it gives better flow
Turbo Powa
18
Oct 2, 2002 06:03 PM
