'94 Del Sol "S" Won't Start
My '94 Del Sol S, Manual 5sp, died while I was out of the car at a cash machine. It literally just died and won't start.
1. I inserted a jumper and tried to get any diagnostic codes, but no codes are displayed. The check engine light does not blink at all! Ok, no fault codes...
2. I checked all fuses to make sure they were all good. Yep! No burned fuses.
3. I knew the fuel pump was having problems, so I replaced the fuel pump and fuel filter. Still no start.
4. Checked for spark. No spark... Checked plugs - Normal. Checked plug wires - normal. Checked distributor cap - normal. Replaced Rotor as general maintenance.
5. Checked Ignition Coil - Failed, resistances off - replaced Coil.
6. Checked Igniter - Failed continuity tests. Replaced.
Still won't start, still no spark. What should I check now? I am getting no fault codes. I have replaced rotor, ignition coil, igniter, fuel pump and fuel filter and don't know what else to test. The two manuals I have don't seem to provide any guidance of what to check now... Does anyone have any ideas?
Thanks,
Rick
Thanks,
Rick
Thanks,
Rick
Thanks,
Rick
Good Luck Rick!
Jdmgsr89
Aug 25, 2013 01:14 PM
JesusGLS
Jan 13, 2013 04:59 AM
