battery not charging ??? please help
Old Jul 11, 2006 | 10:12 AM
RemoveGiantWingOnYourCar's Avatar
Default battery not charging ??? please help
89 Si 194,000 miles
My battery wasn't charging so I figured the original 17 yr old alternator was dying and I replaced it. Worked for a short time but now the battery still isn't charging.
It could be the 7 year old duralast battery is dead but I don't want to throw money at this beater if it is something else that is wrong. It would cost $90 to diagnose it.
Any thoughts????
I'm about to give up on it and buy a new civic but maybe it is something simple to fix.
Old Jul 11, 2006 | 10:15 AM
Hawkze_2.3's Avatar
Default Re: battery not charging ??? please help (RemoveGiantWingOnYourCar)
If the alt is new, then check all the wiring in the charging system if it's not the battery. It could be pretty rusty and corroded on a 17yr old car...
Old Jul 11, 2006 | 10:21 AM
cdk001's Avatar
Well.. do a load test on the batt.. it will tell you if it's your batt, or alt. that needs to be replaced.. .. you could get a load tester on the net less then $90.. but I'm sure if you go to your local auto parts store they could to a load test for you for free
Old Jul 11, 2006 | 10:32 AM
prelude1897's Avatar
might need some new battery connectors.
Old Jul 11, 2006 | 11:45 AM
Default Re: battery not charging ??? please help (prelude1897)
thanks for the ideas, the guy at autozone wouldn't do a load test because he thought it might kill the battery, but maybe i'll try that at another autozone much closer to home
i did replace the battery connectors a year or so ago and they look good
the wires at the battery and alternator all look good, but i could follow them and see if something is corroded elsewhere
Old Jul 12, 2006 | 07:36 AM
i took the car to the shop this morning and they say the alternator is bad, turns out the one i put in was bad, so that sucks!!!!!!!!!!!!!!! i try to fix the thing and i get bad parts, you assume when you buy a part that it works, but i guess not
ef9one6
Apr 17, 2007 07:31 PM
Byaaah!
Jan 30, 2007 12:06 AM
emegge
Aug 10, 2006 04:07 PM
KleenEX
Dec 30, 2004 01:52 PM
TIRENECK
11
Dec 12, 2003 09:05 PM
