Need help breaking loose the Crank pulley bolt
Old Jul 11, 2006 | 08:16 AM
prelude1897's Avatar
Default Need help breaking loose the Crank pulley bolt
Sup everyone, my friend and I are having a major problem breaking loose the crank pulley bolt. We're using the special crank pulley tool and a 4ft breaker bar. The problem is, we've broken 4 reducers, cause we're using reducers from a 3/4 down to 1/2 and we've snapped 4 of them already. What is another method we can use to break free the crank pully bolt so I can change my T-belt?
Old Jul 11, 2006 | 08:22 AM
ShinobiLude's Avatar
Default Re: Need help breaking loose the Crank pulley bolt (prelude1897)
Me and my pops used a torch and heated around the bolt to expand it. Key is not to heat the bolt. After all the trying it came right off after doing that. Hope that helps some.
Old Jul 11, 2006 | 08:27 AM
Default Re: Need help breaking loose the Crank pulley bolt (ShinobiLude)
but isn't there some type of oil seal around there?
Old Jul 11, 2006 | 08:38 AM
soundbomber's Avatar
are air tools out of the question?
Old Jul 11, 2006 | 08:51 AM
Default Re: Need help breaking loose the Crank pulley bolt (soundbomber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">are air tools out of the question?</TD></TR></TABLE>
We tried, but didn't work, but we were using one that was only pushing about 130psi.
Old Jul 11, 2006 | 08:54 AM
Jagan'92's Avatar
use an old belt around the pulley and some large vise grips or pipe clamp to hold the pulley/belt while the other person turns the bolt.
Old Jul 11, 2006 | 09:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">We tried, but didn't work, but we were using one that was only pushing about 130psi. </TD></TR></TABLE>see if you can get your hands on the ingersoll rand titanium air gun, it's a 1000 ft/lbs initial torque, you shouldn't have any problems, otherwise...spring for a 3/4" socket?
Old Jul 11, 2006 | 09:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">see if you can get your hands on the ingersoll rand titanium air gun, it's a 1000 ft/lbs initial torque, you shouldn't have any problems, otherwise...spring for a 3/4" socket?</TD></TR></TABLE>
My friend was looking at some 3/4 sockets and he said none would fit through the crank pulley tool, so I guess I'll see if I can find someone or some place that will take it off for me. Thanks for all the help guys
Old Jul 11, 2006 | 09:47 AM
98TypeSH's Avatar
i used a 1/2" drive snap on impact socket on a breaker bar with the end of a floor jack handle on it to make the thing at least 6 feet long. Then i put the bar in the air and jumped on that sucker. Poped off 2nd try. ( also using the snap on crank pully holder.)
No torch, or liquid wrench or anything. Re-torqing that thing is fun as well
Old Jul 11, 2006 | 09:52 AM
garveysboy's Avatar
I dont know if this will help you or not but mine pulley broke a while back and i know that it takes 181 lbs. to tighten so its pretty hard to get off. i got mine off with an electric impact a buddy had. took a while but it came off.
Old Jul 11, 2006 | 10:03 AM
KB96VTEC's Avatar
we had to have one person stand on the brakes with the car in gear and one person jam a screwdriver in the flywheel opening (near your engine code) and then i gave the breaker bar EVERYTHING i had...finally it broke loose and i got a busted knee for my troubles.
Old Jul 11, 2006 | 10:20 AM
Speedra500's Avatar
Default Re: (thaJooze)
haha, i remember the days before i got a good impact, what was worse on my car was the spindle nuts on the axles, but on the crank if you can get the car up high enough or use a large extension you can get a 1/2" drive breaker bar and like a 5 ft cheater bar like 98 type sh was saying, i think those adapters are generally not as strong, or go out and buy a nice impact, sometimes it just takes a massive impact and thats all there is to it
Old Jul 11, 2006 | 10:31 AM
Default Re: (Speedra500)
We tried all that. We used a cheater bar ontop of the breaker bar, along with a few extensions and jack stand, and still snapped 4 of those 3/4-1/2 reducers
Old Jul 11, 2006 | 12:33 PM
98TypeSH's Avatar
Default Re: (prelude1897)
then get a 1/2" drive breaker bar and socket. You wont break those. Get craftsmen at the least so in the unlikely event you DO break it, you get a new one for free
Get the car off the ground and on jack stands. Get the socket and breaker bar on so the bar is at about 45 degrees in the air in front of the car. If you are skinny lightweigh people, it may take a few of you all on the bar to bust it loose. Just my 210lb *** jumping on that sucker poped it.
It has just enough play to get the bar level with the car, then lean on it and put all your weight into it. have a friend jump on you if necessary, lol. And when it comes lose, have a good trip to the ground.
Old Jul 11, 2006 | 01:29 PM
Pullig's Avatar
Default Re: (98TypeSH)
where did u get that special crank pulley holder at?
Old Jul 11, 2006 | 02:00 PM
Default Re: (Pullig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pullig &raquo;</TD></TR><TR><TD CLASS="quote">where did u get that special crank pulley holder at? </TD></TR></TABLE>
Hit this guy up, cause he works for Honda in the parts depo. and can get you a good price on parts. Just tell him Brian told you about it
Mike Blinkinsop
952-892-6253
mnhondaparts@gmail.com
Old Jul 11, 2006 | 03:11 PM
PrettyLude's Avatar
brian, not this again, lol, i told you man, for any impact gun to be very effective, you would need a very good comopressor with a lot of air. something that is dual staged.
barrera
Oct 11, 2010 07:17 AM
goldfinger93030
Feb 13, 2010 06:39 AM
vaspeeder
Engine Management and Tuning
May 2, 2009 10:11 PM
thrty8street
19
Feb 20, 2005 07:52 PM
93gsrcoupe
Sep 30, 2004 09:54 PM
