if the car isnt grounded right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_V_TurboSi »</TD></TR><TR><TD CLASS="quote">certain grounds will make items not function.. Sometimes it will also cause your car not to start..
What ground isnt hooked up?</TD></TR></TABLE>
the one on the front of the valve cover
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx!go »</TD></TR><TR><TD CLASS="quote">maybe if you knew how to work on a car dale you could fix this problem your self??</TD></TR></TABLE>
it wasnt my car... and i did fix it
this post was made to prove someone wrong... ***
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">hard starting, dim lights, not a good spark, etc etc,</TD></TR></TABLE>
have had them not start at all cause of grounds on the motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DBL »</TD></TR><TR><TD CLASS="quote">
have had them not start at all cause of grounds on the motor</TD></TR></TABLE>
yea this is exactly what i told the kid.... he wouldnt believe me so i made this thread
have had them not start at all cause of grounds on the motor</TD></TR></TABLE>yea this is exactly what i told the kid.... he wouldnt believe me so i made this thread
if he doesn't believe you, just disconnect the ground from the tranny to the frame of the car and tell him to try starting it...then ask him if he believes you now...works everytime for me against tools who think they know more than me...btw, if something goes wrong, don't blame me...haha...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orientalgunz_00 »</TD></TR><TR><TD CLASS="quote">if he doesn't believe you, just disconnect the ground from the tranny to the frame of the car and tell him to try starting it...then ask him if he believes you now...works everytime for me against tools who think they know more than me...btw, if something goes wrong, don't blame me...haha...</TD></TR></TABLE>
yea he had the ground wire on his power steering bracket... and his car wouldnt start.... then i moved it to the valve cover and it started... but now the starter is pretty much fucked from him having it like that
I'll simplify it best I can..
grounds complete circuits, circuits are needed to power something.. If your fuse box isn't grounded, then everything that has a fuse that runs through that box won't be grounded and won't work.. etc. etc. etc.
If a ground that grounds out ur distributor isn't connector, ur car won't run..
em1mike
21
May 1, 2007 04:07 PM
Marble
Feb 10, 2006 05:18 AM
