Special Type of Paint for Bodykits??
Old Jul 10, 2006 | 02:26 PM
Fatty_1775's Avatar
Default Special Type of Paint for Bodykits??
I have a bodykit and the sideskirts are molded on to my car. The driver side keeps cracking and has been repainted many times. Is there a special type of paint or clearcoat needed? Someone told me paint that they use on Saturns might help. Any ideas?
Old Jul 10, 2006 | 02:57 PM
Chrisfrom1986's Avatar
someone did shitty bodywork.
Old Jul 10, 2006 | 05:34 PM
leeminho86's Avatar
Default Re: Special Type of Paint for Bodykits?? (Fatty_1775)
Type of paint shouldn't matter as long as prep work was done properly.
Old Jul 10, 2006 | 05:54 PM
eg6sir-s's Avatar
Default Re: Special Type of Paint for Bodykits?? (leeminho86)
prep work is key bodykit or otherwise.
Old Jul 10, 2006 | 05:59 PM
JSPECSIR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fatty_1775 &raquo;</TD></TR><TR><TD CLASS="quote">--------------------------------------------------------------------------------
has been repainted many times.</TD></TR></TABLE>
thats probably part of the problem. second if the side skirt isnt mounted extremely sturdy it will continue to crack. when driving, wind under the car could cause it to vibrate, or your exhaust or anything really. also how is it attached to the car before it was molded? screwed, glued, double sided tape, any idea?
Old Jul 10, 2006 | 07:33 PM
Cold Fyre's Avatar
If you get it painted again and don't want to go through the hassle of getting the body work redone, just ask them to put some plasticizer (sp) in the paint. That should give the paint some ability to move with the kit.
Old Jul 11, 2006 | 12:59 AM
Fatty_1775's Avatar
Default Re: (Cold Fyre)
it was glued and bolted on, funny, nothing has happened to the other side
Old Jul 11, 2006 | 03:27 AM
CivicEX13's Avatar
it is prolly goin to crack because the body likes to flex....i have never seen a daily driven car with a molded kit that wasnt cracked or had been cracked...there is really not to much you can do about it when you are trying to bond fiberglass to metal
Old Jul 11, 2006 | 04:07 AM
JSPECSIR's Avatar
Default Re: (CivicEX13)
if its the drivers side maybe its because you open and close that door alot. everytime you shut it it probably jars it loose.
Old Jul 11, 2006 | 04:57 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (JSPECSIR)
ahh.. anther ruined civic
Old Jul 11, 2006 | 03:52 PM
Fatty_1775's Avatar
Default Re: (GarageAlchemist)
how about paint thats on saturns? the body on those cars can bend or flex a bit, right? im gonna look into the plasticizer
Old Jul 11, 2006 | 04:16 PM
JSPECSIR's Avatar
Default Re: (Fatty_1775)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fatty_1775 &raquo;</TD></TR><TR><TD CLASS="quote">how about paint thats on saturns? the body on those cars can bend or flex a bit, right? im gonna look into the plasticizer</TD></TR></TABLE> i dont know what that **** is most shops just use something called flex agent.
Old Jul 11, 2006 | 04:19 PM
sicky's Avatar
grammer nawzi
Maybe remove the kit?
Old Jul 11, 2006 | 05:06 PM
Fatty_1775's Avatar
Default Re: (sicky)
is that possible to remove sideskirts that are glued on? Would it be hard to put it back to stock? the guy who did all my body work originally is not around anymore.
5lugSlug
Paint and Body
Aug 23, 2007 06:30 AM
blkteggy
Paint and Body
12
Aug 10, 2007 07:25 AM
civiccoupe94
Jul 29, 2005 12:29 PM
filipinoguy
May 16, 2004 10:40 PM
HondaLife2126
Apr 27, 2003 02:13 AM
