will cluster from 89 4dr fit into a 89 3dr?
Old Apr 19, 2002 | 10:00 PM
flat-blk-HB's Avatar
Default will cluster from 89 4dr fit into a 89 3dr?
i am thinking it will i picked it up from a friend for 2 reasons.1:it has a tach & 2:my speedo needle is broken,so i have no idea on how much speeding i have been doing latley.Also i heard this is a straight swap,granting that it will work.but will the tach work,there is only 2 places for plugs on the back of the 4dr cluster,and the place for the speedo of course.Thx in advance for the help.
Old Apr 19, 2002 | 10:09 PM
RexB16's Avatar
Default Re: will cluster from 89 4dr fit into a 89 3dr? (89EF-BCUMBIE)
hello?
Old Apr 19, 2002 | 10:27 PM
Default Re: will cluster from 89 4dr fit into a 89 3dr? (RexB16)
what do you mean-Hello?
Old Apr 20, 2002 | 08:58 AM
i put it in this morning and everything went fine.it all works and now i have a speedo.no more worring about the cops when they are behind me!
Old Apr 20, 2002 | 09:11 AM
No More Civic's Avatar
I have the guage cluster from an automatic 4dr in my manual hatchback and it works perfectly.
Old Apr 20, 2002 | 09:16 AM
Default Re: will cluster from 89 4dr fit into a 89 3dr? (SlowCivicDX)
does the cluster have a gauge showing what gear your in(automatic). my friend and i did a auto to 5-spd conver in a 2000 EX and when he gets on it some times the gauge moves like from park to Drive 1 and then to reverse it's kinda messed up.but thanks for the info.
Old Apr 20, 2002 | 10:34 AM
CdTriX's Avatar
um... i have an 89 4dr civic and i do'nt have that gear stuff your talking about on the gauge... those came with the EGs i think my dx doesn't have it
Old Apr 20, 2002 | 02:45 PM
Default Re: will cluster from 89 4dr fit into a 89 3dr? (CdTriX)
yeah maybe only the newer civic's have them wasn't sure.THX
Old Apr 20, 2002 | 02:49 PM
si foo's Avatar
I'm parting out my 89 civic si hit me back at MRCRX8@AOL.COM if your interested in the cluster.........
Old Apr 22, 2002 | 05:16 AM
virginia_dude's Avatar
As long as you get one out of a 88 or 89 it will fit and work perfectly, the 90-91 is a little different. I have a LS cluster in my '89 hatch, the redline is a little too low for my ZC but I know where it should be anyway, heck, Aftermarket tachs have no redine on them anyway.
[Modified by virginia_dude, 9:17 AM 4/22/2002]
Old Apr 22, 2002 | 08:43 AM
Default Re: will cluster from 89 4dr fit into a 89 3dr? (virginia_dude)
what year TEG cluster are you using?I have one from a 91 but i am really sure it wont work.thx
Old Apr 22, 2002 | 11:26 AM
Mine isn't a TEG its a Civic LS 4 door cluster, tach has a 6,800 rpm redline but its plug and play and dirt cheap in the wrecking yards. as long as you go 88-89 OR 90-91 you match the year group of your car. You can make the other fit but it needs additional work that I cant explain since I never did it. The LS has a tach and so do almost every other one BUT the DX. the HF has the lowest redline, somewhat under 6,000. But I think even it is Plug and play, they all look identical except for where the redline starts on the tach face.
Old Apr 22, 2002 | 11:34 AM
wronghand's Avatar
No such thing as a civic ls. Civic lx maybe.
Old Apr 22, 2002 | 11:39 AM
Default Re: will cluster from 89 4dr fit into a 89 3dr? (wronghand)
OK, I stand corrected I am sure that is what I should have said. It was an L something so was probibly the LX. I got it from a local yard in MD near DC for only $25 it was out a a car that had 86,000 showing. Thats a hell of a lot cheaper than everyone is asking for Si clusters and the Redline is the only difference. But it definately cam out of a civic 4 door, not a teg.
[Modified by virginia_dude, 3:48 PM 4/22/2002]
Old Apr 22, 2002 | 11:49 AM
Old Apr 22, 2002 | 12:06 PM
do you mean LX?i have never heard of a LS 4 door.but yeah ihave already got the LX cluster working properly in my car.
Old Apr 24, 2002 | 04:30 AM
yes an 88 or 89 cluster would work plug and play in your 89. same as mine. Why pay over $100 for a Si cluster when the tack redline is the only difference. Heck creative use any some paint can change that, me I left it as is.
Voodoo7
11
Mar 25, 2012 05:58 PM
new_climber
Mar 12, 2009 09:17 PM
allnapower
Feb 24, 2005 02:03 PM
Civic89
Jul 18, 2002 10:34 AM
REDBARON
Jun 28, 2001 02:18 AM
