Threw a CEL code 3 MAP and car running in Limp Mode and won't stay running...
Old Jul 10, 2006 | 01:26 PM
HickamHatch's Avatar
Default Threw a CEL code 3 MAP and car running in Limp Mode and won't stay running...
Hi, I have a swapped LS motor with OBD1 ecu in my 93 hatch. I am running the P75. I am having a problem with my CEL coming on for my MAP sensor (Code 3). I have a chipped ECU and a basemap. When I start my car the car runs very rich with smoke pouring out the back, will not rev past 4k, and doesn't want to idle.
I have to press the gas a bit to get it started and for it to stay running for even a couple of seconds, then it just bogs down and dies. I know my MAP and TPS sensors are hooked up right cause i checked the wires.
Any help appreciated!
Old Jul 10, 2006 | 06:27 PM
jedsus's Avatar
Default Re: Threw a CEL code 3 MAP and car running in Limp Mode and won't stay running... (93civic96ls)
iam having the same problem.....but my car will stay fine it idle but when i rev it....it start to backfire......
Old Jul 10, 2006 | 06:35 PM
boostedcivicsir's Avatar
Mr. Badwrench
the chip isnt setup for a 3 bar is it?
Old Jul 10, 2006 | 07:11 PM
jedsus's Avatar
Default Re: Threw a CEL code 3 MAP and car running in Limp Mode and won't stay running... (boostedcivicsir)
what about mines....i have a stock p72 ecu
Old Jul 10, 2006 | 08:07 PM
no, its not set up for 3bar.. I put it back to stock map when we were doing some tests. I do know that the chip was bad cause it was throwing a constant CEL.. When we hooked up the romulator to do some tests, I got the MAP CEL (Code 3). So I am getting a new chip on Wed., but it still doesn't fix it.
I need to figure out how to get rid of the MAP CEL..
Old Jul 11, 2006 | 02:46 PM
anyone
Old Jul 14, 2006 | 07:07 PM
Well today my friend let me hook up my ECU in his hatch and his ran, no rev limiter like limp mode, but still had the solid cell!
Can a ECU still run with a solid cell and be faulty at the same time?
Old Jul 14, 2006 | 09:25 PM
D16SohcVtec's Avatar
You should get a volt meter and check the wires to see if you have a break within the wire. This isn't MAP sensor related, but I once threw a code for a sensor and when I bought a new sensor it still didn't fix it. It ended up being a bad wire and so when I fixed that the CEL went away and hasnt came back since.
Old Jul 14, 2006 | 09:28 PM
qfast817's Avatar
Default Re: Threw a CEL code 3 MAP and car running in Limp Mode and won't stay running... (D16SohcVtec)
what size of injectors are you runing, do you have a resitor box
Old Jul 15, 2006 | 10:01 PM
Default Re: Threw a CEL code 3 MAP and car running in Limp Mode and won't stay running... (qfast817)
dude, the solid CEL was in both cars. I'm thinking its the ecu. I know my plug is bad on my stock map sensor. I have already checked all that out. I did also have it chipped for the 2.5bar map and 550cc injectors. Car is obd1 so I shouldn't need the resistor box right?
I am now beginning to think that it wont stay running cause 1. ECU is fried and 2. 550cc injectors plus no map sensor on (stock ecu =Jumper cut) is flooding out the engine stalling it out.
I think all I need to do is replace the ECU with another chipped on and have the same chip I already have and see if that works. Main reason I think the ECU is bad is cause the solid cell in both cars I have tried it in, but his runs, and mine doesn't. And I stated why I dont think mine runs up above.
Please correct me if I might be wrong.
Modified by 93civic96ls at 4:16 PM 7/16/2006
Old Jul 18, 2006 | 02:52 PM
I just picked up a map sensor plug, but now i need one more injector since one of mine is broke.. Anyone else have any ideas?
Old Jul 21, 2006 | 05:30 PM
its definatly the ECU. just put stock injectors and hooked the stock map sensor and it runs... just the IAVC plug doesnt stay on so i have to get a new one, but other than that, its doesnt smoke, it purrs like a kitten, and its ****** loud... anyways, im ready to put the turbo back on and tune this bitch!
hondalove414
Mar 20, 2011 08:11 AM
efnborder
Aug 14, 2010 10:19 PM
hotimportcrx
Mar 31, 2008 10:28 AM
jays93eg6
Sep 25, 2006 10:23 PM
