MI: B18B w/GSR trans, EK ready, Hondata S100b, JRSC package deal!
Old Jul 10, 2006 | 12:56 PM
klungemonger's Avatar
Default MI: B18B w/GSR trans, EK ready, Hondata S100b, JRSC package deal!
I'm selling everything I have! Going H-series now. Here's the lowdown:
1) 1997 B18B complete swap, runs strong but does smoke a bit sometimes. I think it needs valve stem seals, although it is possible it's rings I just don't know. Otherwise a great motor, has new t-belt. Comes with GSR hydro tranny, 99-00 Si shift linkage (less then 1yr old), all mounts for EK including P7J a/c mount for your D-series compressor, axles & midshaft.
2) JRSC kit for B18B, all mechanical pieces needed. You need belt and charger oil. The FMU normally with the kit is not included, you won't use it anyways...see #3 below...
3) OBD1 P75 ecu with Hondata S100-boost already installed. Just need to burn your own basemap/tune onto the chip
Asking $2100 for the whole dealio!!! I also have a new pan gasket, valve cover gasket, spark plug seals, and v.c. grommets so if you do the stem seals or rings you don't have to buy this other necessary stuff as it's included. PM me for other details, particularly about timing of the sale...
Old Jul 10, 2006 | 11:08 PM
mRek9R's Avatar
Default Re: MI: B18B w/GSR trans, EK ready, Hondata S100b, JRSC package deal! (klungemonger)
bump for an SHO mate! Good setup, good price! 8)
Old Jul 13, 2006 | 05:33 AM
Thanks dude, and another bump for good measure...
Old Jul 17, 2006 | 09:06 AM
up for Monday morning...
Old Jul 17, 2006 | 03:19 PM
stewmaster-k's Avatar
Default Re: (klungemonger)
would you sell just the tranny? i know you would like to sell it all, but i need a tranny ASAP so i would love to get that one! let me know in a PM. thanx
Old Jul 17, 2006 | 09:26 PM
Even if I wanted to I couldn't, it's all still in the car and I'm out of country working for a couple more months so can't pull it out!
Old Jul 23, 2006 | 08:48 PM
Here we go again...
Old Jul 24, 2006 | 08:42 AM
rallystyle's Avatar
willing to sell just the motor swap? if so how much?
Old Jul 24, 2006 | 08:45 AM
Yes, but I might have a slight change in plans and be building a big-bore GSR block now so I may be keeping the mounts and linkage...I will still sell the swap w/o that stuff though and the GSR trans will still be included...I'll think of a price...
Old Jul 30, 2006 | 08:02 PM
vsmhatched's Avatar
how much for just the blower?
Old Jul 30, 2006 | 08:27 PM
selling the JRSC kit for $800 shipped w/o the Hondata or engine.
Old Jul 30, 2006 | 09:57 PM
vsmhatched's Avatar
how much picked up
cause i live close and i'll come pick it up
also do you have the FMU b/c if not i kinda need that ECU
Old Jul 30, 2006 | 10:34 PM
I'll knock off $40 for a pickup. I'm in southeast Michigan. No I don't have the FMU.
Well, I kind of might have to keep the ecu for a little while along with the swap, until I get the replacement motor put together...plans changed and I'm probably not doing an H22 I'm building an all-motor GSR block...I'll let you know on that though. I might sell it in a couple more months.
Old Jul 30, 2006 | 11:42 PM
vsmhatched's Avatar
i have an all motor OBD1 skunk2 ecu its a chipped p28....
if that helps any..
Old Jul 31, 2006 | 07:45 AM
I have a socketed P72 sitting around also...Initially I planned to sell the Hondata but I might end up with like 12-13:1 compression on pump fuel and ITB's...so I'll need more than just chipping to get it running right.
klungemonger
Aug 23, 2006 06:52 AM
00TypeR
Mar 9, 2006 09:16 AM
Atheist
Apr 18, 2004 07:22 AM
.Beaver
Jul 25, 2002 01:51 PM
