MSD 3bar map problem
Old Jul 10, 2006 | 12:40 PM
Chris22215's Avatar
Default MSD 3bar map problem
I just installed an msd 3bar on my integra using hondata's write up. The voltages check out to 1.59 between the ground and the map signal with the key on. But i can't crank the car on crome pro, and yes i've changed it to a 3bar map. The car will crank and rev for a second, then it'll die. Is there anything that i'm missing? I've got a datalog that I can attach if someone would like to look at it.
All I did was remove my GE vac log and drill out another hole, and add the line there for the map.
Old Jul 10, 2006 | 05:44 PM
Chris22215's Avatar
Default Re: MSD 3bar map problem (Chris22215)
nevermind. I'm not sure what happened, but I changed to crome2.0. After that everything worked out fine.
ef9itb
Engine Management and Tuning
Jun 26, 2010 06:25 AM
acuralovar
Dec 21, 2009 02:27 PM
Bbasso
Jan 25, 2005 06:09 PM
