eg8 leaking fluids inside
Old Jul 10, 2006 | 08:17 AM
LuCkYcOuPe's Avatar
Default eg8 leaking fluids inside
Some fluid is staining the carpet under the gas pedal inside my bro's 94 civic 4dr, noticed it immediately. hes concerned just needs some assistance in locating the problem thanks
Old Jul 10, 2006 | 08:28 AM
Urban Camo's Avatar
Default Re: eg8 leaking fluids inside (CRF1600ej1)
under gas pedal? or brake pedal? sometime the brake master/booster will leak back into the vehicle, along with the clutch master if it is 5 speed. you should be able to tell which one by checking the fluid level if it is enough to stain the carpet.
Old Jul 10, 2006 | 08:29 AM
birds_sol_94's Avatar
what kinda fluid substance is it..?! is light oil-ly.. dark... ??? need more info..
Old Jul 10, 2006 | 08:35 AM
LuCkYcOuPe's Avatar
Default Re: eg8 leaking fluids inside (birds_sol_94)
under the gas pedal it's light, ive checked the brake fluid & power steering and they were fine.
Old Jul 10, 2006 | 08:50 AM
instructor74's Avatar
I think you only have 3 options on what it could be Brake fluid which is also used in the clutch (pull the carpet back and look around the clutch and brake ped. 2nd it could be a leak in the heater core but you should smell coolant in the car. 3rd the ac unit is leaking if your car has it but that should be on the pass side of the car.
Old Jul 10, 2006 | 08:51 AM
is it a 5speed... if it is check the clutch fluid resivoir... umm you might maybe have a water leak...
ray.riddler92
May 4, 2011 01:00 PM
95ludeSE_bottle
Apr 11, 2008 02:39 PM
BB1_VTEC
Oct 1, 2006 08:21 PM
BB1_VTEC
Jul 12, 2006 09:41 AM
mrpeabody
Mar 19, 2004 06:50 AM
