eg8 leaking fluids inside
Some fluid is staining the carpet under the gas pedal inside my bro's 94 civic 4dr, noticed it immediately. hes concerned just needs some assistance in locating the problem thanks
Re: eg8 leaking fluids inside (CRF1600ej1)
under gas pedal? or brake pedal? sometime the brake master/booster will leak back into the vehicle, along with the clutch master if it is 5 speed. you should be able to tell which one by checking the fluid level if it is enough to stain the carpet.
I think you only have 3 options on what it could be Brake fluid which is also used in the clutch (pull the carpet back and look around the clutch and brake ped. 2nd it could be a leak in the heater core but you should smell coolant in the car. 3rd the ac unit is leaking if your car has it but that should be on the pass side of the car.
95ludeSE_bottle
04-11-2008 02:39 PM
