Hey what do you think of this?
Just out of curiosity, I don't know the size of the K20 or any of the specs and measurements?? (RSX Motor), but do you think when the time comes that the K20C( DC5 Type R motor) will fit in the DC2? Just wondering.......Thinking engine swap or rebuild after 100k?
[Modified by Type R 98-0352, 10:22 PM 4/19/2002]
well the k20c motor mounts tranversly(sp?) with the intake manifold in the front and the exhaust manifold in teh rear. i also heard that the motor spins the opposite way unlike most hondas on the road today. even if it worked, you would have to fabricate a lot of things and in the end its not worth it. you'd be better off buying a used b18c5 and save the money to mod it like crazy.
No the newer Honda engines including spin the opposite direction of the older Honda engines including your B18C5. I believe our engines spin counter clockwise, tyhe newer ones, such as the K20C, rotate clockwise. Also I believe the transmission is on the opposite side and the exhaust no exit directly toward the back of the car. The whole engine is pretty much flipped i Believe. Correct me if I'm wrong.
Damn 2 replies in the time it took me to write mine. And yes anything is possible with enough money, and time but it wouldnt be very finacially locigal to turn a FWD car into a RWD car.
hlee5363
28
May 9, 2008 02:03 AM
deez sniderz
Jun 8, 2003 12:46 AM
GQ 05YellowEVO8
Sep 10, 2001 03:55 PM
F120man
Sep 2, 2001 07:30 AM
