ls.transmission????????/
Old Jul 9, 2006 | 11:00 PM
95_red_dc's Avatar
Default ls.transmission????????/
My ls tranny fill plug is strip and i can not get it out to fill it. I heard that you can fill through the hole on top of the tranny with a plastic plug on it. Is ti true and how many qurts does a ls tranny hold. Do any body outn there ahve any tricks our suggestions on how to get the plug out, i have try vise grips.
Old Jul 9, 2006 | 11:24 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: ls.transmission????????/ (ls_swaped_crx)
Fill through the speed sensor on the top. Its 2, 10 or 12mm bolts.
Tranny takes 2.3 quarts
Trq drain plug to 33ftlbs
The speed sensor is probably 8ftlbs
Old Jul 9, 2006 | 11:29 PM
Ls_V_TurboSi's Avatar
Default Re: ls.transmission????????/ (00IntegrAllmotoR)
How'd you strip that? Isn't that a 17mm?
Old Jul 9, 2006 | 11:44 PM
95_red_dc's Avatar
Default Re: ls.transmission????????/ (Ls_V_TurboSi)
actually i thought it should be to as my past tranny were but i just bought this one it is any a1 transmission it was a 15mm bolt but not anymore. It is in there so tight, it is rounded off pretty bad. So i used a drimel tool so it is not so rounded, flaten out a little bit, and try to use some vise grips to clamp on it. would that hole at the top of the tranny work?
esean93
Feb 12, 2009 06:17 PM
dL_EG6
Feb 19, 2007 09:06 AM
95_red_dc
Jul 10, 2006 12:09 AM
LOWNSLOW
Apr 11, 2004 11:47 AM
wicx
Aug 18, 2002 11:53 PM
