Check engine light after clutch install
Old Jul 9, 2006 | 09:58 PM
passwordhatch's Avatar
Default Check engine light after clutch install
i drive a 96 civic hatchback cx, i instaled a new stock clutch 2 days ago and had noticed that my clutch pedal was very soft, there are no grinds when shifting and i can grab gears very well, the clutch fluid is at normal levels and there are no leaks, i filled the tranny up with oil when i was done with the repair.
the problem is that my check engine light came on tonight as i was driveing home, the car runs no different with the light on. one thing i can notice is that when i really get on the gas through the gears it seems like it loses power shortly and then catches up and drives normal, thats only though the first 2 gears, i also removed the complete a/c system at the time if that helps.
i really trying to figure out why im losing power through the gears and what caused the check engine light to come on.
help will be greatly appreciated
Old Jul 9, 2006 | 10:31 PM
Default Re: Check engine light after clutch install (passwordhatch)
Late night bump
Old Jul 9, 2006 | 10:36 PM
Luserkid's Avatar
Did you check the code?
Old Jul 9, 2006 | 11:26 PM
Ls_V_TurboSi's Avatar
Default Re: Check engine light after clutch install (Luserkid)
what he said ...
Thats the first step to fixing the problem
Mj916
Honda CR-V & Element
Jan 5, 2019 12:10 PM
DaMmniTz
Feb 20, 2005 12:55 PM
6thgenaccord1
Nov 13, 2003 10:19 AM
6thgenaccord1
Nov 13, 2003 09:23 AM
blacksi00
Apr 29, 2003 10:03 PM
