Blowin Smoke NEED HELP please!
Old Jul 9, 2006 | 05:17 PM
88whitehatch's Avatar
Default Blowin Smoke NEED HELP please!
Hey guys i need help with my motor. When i reach about 3k rpms, my car is blowin smoke so bad that i can not even seee behind me. i pulled my plugs to see if they were wet, but the bottom where it fires is clean as hell. But the top is on like to cylinders is wet with oil(the plugs). i was thinking it was my rings, but after looking at them. i am thinking diff. The smoke is white. non turbo if you guys could help me that would be sweet. thanks
Old Jul 9, 2006 | 06:10 PM
88crxhfb16's Avatar
Default Re: Blowin Smoke NEED HELP please! (88whitehatch)
BLOWN head gasket?? anyone else confirm. Coolant usually burns off white, oil would be darker.
Old Jul 9, 2006 | 06:30 PM
civicjdmb16a's Avatar
Default Re: Blowin Smoke NEED HELP please! (88crxhfb16)
my brothers hatch is having same prob. he said he had same amount of white smoke you have when car was over 2k but when i stood behind the car it was a real light bluish color and smelled like burning oil. The only reason i dint think it would be your head gasket is that your pistons are dry but the tips of your plugs are wet from oil, same as my bro. Could be valve seals, cause the oil drips right on the plug.
Did your car smoke at all when at idle for a while?
Piston rings would smoke at higher rpm's........
Check to see if you have oil in your radiator overflow and see if you have coolant on your dipstick....(milky spots) just to see if it is your head gasket.
Most important.........Good Luck
Old Jul 9, 2006 | 06:35 PM
harmonator84's Avatar
Default Re: Blowin Smoke NEED HELP please! (civicjdmb16a)
i would check the head gasket.
Old Jul 9, 2006 | 06:36 PM
yz125rider21's Avatar
compression test it and come back with the readins but if your blowing that much smoke its head gasket or you dumped like 2 gallons of Gunk down your vaccum line :-)...but check the oil and coolant and see
Old Jul 10, 2006 | 09:21 AM
Well thanks for all the info guys really appriciate it. I think i will go with the head gasket to see if that helps.
codyweiss97
Mar 8, 2014 11:04 AM
jyacoba2009
Jun 11, 2010 07:46 AM
Joeski99Si
Aug 2, 2009 11:25 AM
mafia
Aug 17, 2007 05:58 PM
cars101
20
May 6, 2007 02:38 PM
