axles
Old Jul 9, 2006 | 04:45 PM
teddy_dc2's Avatar
Default axles
how do i get the new axles on the passenger side back into the tranny? looks like a lock ring or some sort on the axle.
also how can i seperate this piece (3 bolt shaft piece that goes on the motor) on the driver side from the axle? i tried prying it but can't seem to get a good angle.
http://i63.photobucket.com/alb...1.jpg
Old Jul 9, 2006 | 04:46 PM
teddy_dc2's Avatar
Default Re: axles (teddy_dc2)
Old Jul 9, 2006 | 04:59 PM
Dartanian's Avatar
Hit the outboard joint with a hammer. Hit it away from the bearing support (the part that is attached to the 3 bolt piece. If you hit it long enough it will separate.
Old Jul 9, 2006 | 05:06 PM
teddy_dc2's Avatar
i will try that, as for getting the passenger side back in?
Old Jul 9, 2006 | 05:35 PM
integra3586's Avatar
Default Re: (teddy_dc2)
just shove it in till u hear it click in
Old Jul 9, 2006 | 05:37 PM
atg1290's Avatar
For the passenger side just wiggle it around untill you hear it clip, there will be a little gap so dont worry...Here is a good link https://honda-tech.com/zerothread?id=382416
Old Jul 9, 2006 | 06:24 PM
Default Re: (atg1290)
^^^good wirte up
but instead of hammering on the axle nut with an impact. or tightening it till its "snug". torque it to proper torque specs 136 ft lbs (maybe 134) i always go to 135. my torque wrench only goes in increments of 5
Old Jul 9, 2006 | 07:01 PM
teddy_dc2's Avatar
Default Re: (integra3586)
well said in the write up, my ball joint on the driver side will not come out, i posted this question before but i will try beating the lca with a hammer and see how it goes. tried prying, jacking it up and the bitch won't even move.
prybar is on a jack. any ideas, methods?
teddy_dc2's Avatar
one more time
Old Jul 9, 2006 | 07:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teddy_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">one more time
do not use a pickle fork to separate the balljoint!!!!!!!!!! it WILL ruin the boot
heres a good write up
not sure if its my comp or not, but the pics might be down. the video should still work
video
edit: hmm looks like it was deleted, i think i have it saved on my hard drive somewhere. ill see if i can find it
Old Jul 9, 2006 | 07:30 PM
click it
thats a 1/2" ratchet in there
Old Jul 9, 2006 | 07:33 PM
teddy_dc2's Avatar
video not working, not sure of how this method works.
Old Jul 9, 2006 | 07:34 PM
teddy_dc2's Avatar
ok the second video worked, where is the ranchet being placed?
Old Jul 9, 2006 | 07:38 PM
teddy_dc2's Avatar
ok i just watched the video about 10 times and i will try that method. (ratchet just goes between?)
Old Jul 9, 2006 | 07:41 PM
ive never tried it. i always have good luck with just smacking the lca with a hammer. sometimes i heat it up with a propane torch. works every time
Old Jul 9, 2006 | 08:09 PM
RJonathan's Avatar
use a "pitman Tie Rod Seperator" its like a fork that grap then there's a middle part that you turn and it'll push the ball joint out. This is better because you wont ruin your ball joint. and for the axles if its to hard get a jack, and jack it up to support the axles so its parralle(SP) to the tranny and use a piece of wood and place it between the axles and your hammer and start tapping it in.
Old Jul 9, 2006 | 08:12 PM
Default Re: (RJonathan)
just be careful when using this method. it can actually mushroom the threads on a ball joint
soon2bdropped
May 9, 2007 06:56 PM
LostAndFound
Jun 13, 2004 01:48 PM
sabertooth
Jan 21, 2004 06:27 PM
Si-Yaaa!
15
Jul 5, 2003 11:22 PM
type Gendy
Jan 19, 2003 06:18 PM
