What are the warning signs that you're water pump is going?
Old Jul 9, 2006 | 02:01 PM
phanatic's Avatar
Default What are the warning signs that you're water pump is going?
Someone mentioned that the squealing sound i hear only when i start my car up could be from water on my belts or the bearings in my water pump are going . Can anyone confirm this?
Old Jul 9, 2006 | 04:25 PM
f2rider's Avatar
Default Re: What are the warning signs that you're water pump is going? (phanatic)
I know when mine was going out it started to drip coolant out of it. I think the part is leaked out of is called the weep hole. Anyway sounds to me like you should check your belt tension or see if a replacement belt is needed. Couldn't hurt to just change out all of the belts and the water pump though, there not expensive at all.
Old Jul 9, 2006 | 07:47 PM
ez12a's Avatar
yes if it is going out, your coolant level will be low. If its low in the overflow tank, try filling it..if it gets low again its leaking somewhere.
Like my dad's civic, its leaking from there. when i fill up the coolant tank to max, it just goes beyond the min point after a couple of weeks.
justint7121
Nov 21, 2010 09:46 PM
dleccord
Jan 11, 2010 06:59 PM
niceprelude
Feb 15, 2009 10:20 PM
wedtm
Mar 26, 2008 07:59 PM
erikiksaz1
Aug 27, 2006 07:45 PM
