Minimum parts needed to do 5 lug conversion on a teg?
Old Apr 19, 2002 | 05:12 PM
fujitsuten's Avatar
Default Minimum parts needed to do 5 lug conversion on a teg?
I've heard a few different answers...
Old Apr 23, 2002 | 08:07 AM
fujitsuten's Avatar
Default Re: Minimum parts needed to do 5 lug conversion on a teg? (fujitsuten)
Old Apr 23, 2002 | 08:39 AM
Volcom's Avatar
Why? If you want a better suspesnion, just get something aftermarket. Type-R's don't need to use their legs and shoes just for some gsr or ls can have a "dope *** 5 lug".
Just my opinion.
Old Apr 23, 2002 | 10:15 AM
deviant94ex's Avatar
New User
Default Re: Minimum parts needed to do 5 lug conversion on a teg? (Alphanumeric)
well if he wants to upgrade to the better brakes of the ITR then he can do this. all you should need is the front knuckle/hub assembly and rear hub assembly along with front and rear rotors, calipers, etc. and dont forget those nice CW or gunmetal ITR wheels. im not 100% sure on all the parts but i believe that will do it. you could also look at http://www.fastbrakes.com as they have big brake kits for the fornt and rear of your car. that my be more of what you are looking for and might save you a bit of money dependig on how far you go with the job. good luck.
CHRIS
Old Apr 23, 2002 | 12:11 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Minimum parts needed to do 5 lug conversion on a teg? (deviant94ex)
Yep you can get a fastbrakes kit which will give you the same brakes as an ITR (redrilled to 4-lug) but w/o having to convert to 5-lug. They also fit under 15" wheels.
Old May 4, 2002 | 06:07 AM
IC x Prince's Avatar
New User
Default Re: Minimum parts needed to do 5 lug conversion on a teg? (PatrickGSR94)
I was wondering this also...I just wanted to go 5 lug. is it necessary to change alot of parts or can I just change the rotors and hubs over to a 5 lug?
Old May 5, 2002 | 10:54 AM
fujitsuten's Avatar
Default Re: Minimum parts needed to do 5 lug conversion on a teg? (UltraGSR)
thats what I also wanted to know
Old May 5, 2002 | 11:44 AM
Isaac's Avatar
New User
Just curious, but what advantages are there for converting to 5-Lug? Aside from bolting the wheel down more.....?
Old May 5, 2002 | 12:00 PM
Jesse H's Avatar
Default Re: Minimum parts needed to do 5 lug conversion on a teg? (Waxing "The Carrot")
Um, about none for 99.9% of us.
Old May 5, 2002 | 08:18 PM
ILOVEGIRLS's Avatar
will the kit fit 14" steelies?
Old May 5, 2002 | 08:20 PM
Volcom's Avatar
Less wheel options.
Old May 5, 2002 | 08:26 PM
Mike B's Avatar
Default Re: Minimum parts needed to do 5 lug conversion on a teg? (Volcom)
4x100 to 5x114.3 spacers/adapters
Old May 5, 2002 | 08:57 PM
uNF$@#!'s Avatar
Default Re: Minimum parts needed to do 5 lug conversion on a teg? (Crazy Bovine)
dammit stop waiting type R parts!
actually maybe the thieves will start stealing from preludes for the 5 lug conversion....
Old May 5, 2002 | 10:05 PM
Isaac's Avatar
New User
Default Re: Minimum parts needed to do 5 lug conversion on a teg? (Jesse H)
What would the .1% be for? I have no idea......anyone?
Old May 5, 2002 | 10:22 PM
badnan's Avatar
looks?
or maybe so it takes the theif longer to get the wheels off?
maybe he wants a complete kdm look, down to the 5 lugs. personaly i think its silly and you should spend your money on something better, like maybe a nice intake manifold if you dont already have it
Old May 5, 2002 | 10:24 PM
ingrate's Avatar
25 Year Member
supposedly it's better handling because the wheels are torqued out more evenly.. but i doubt you'd notice any difference
Old May 5, 2002 | 10:37 PM
Isaac's Avatar
New User
Default Re: Minimum parts needed to do 5 lug conversion on a teg? (In7egrity)
So basically a very very minimal difference.
xlasianizelx
Jan 13, 2011 05:54 PM
Nighthawk R18
Honda Civic (2006 - 2015)
10
Oct 24, 2007 03:56 AM
campbuds
Aug 7, 2004 08:25 AM
W.O.P.
Mar 8, 2004 04:50 AM
Doogie Howser
Jun 18, 2002 08:47 PM
