Battery Relocation Help
I am almost finished with my relocation, I ran the positive wire through the fire wall into the trunk, and I grounded the negative to my trunk where the spare tire used to sit. The car turns on and has all power, but just won't turn over...I ran my 8g wire to my fuse box and my 2g wire to my starter. Anything i am missing? If it has to do with power to the transmission let me know as well, because i think that is why it's not starting up... thank you
sorry for long post
- i used a wire brush and scraped away the paint so it's just metal where i mounted my ground in the trunk
sorry for long post
I'd definitely check all of your grounds. Make sure everythings tight at the fuse box and starter. I just did a relocation in my crx not too long ago and I think the only place you can mess up at is if you mess with the grounds.
Ok so wiring it to the transmission has nothing to do with it, like it was originally??? i checked all of my grounds and disconnected the wires from the starter and from the trunk, and still nothing..all i hear is a buzzing sound from the starter it sounds like when i turn the key all the way?? help please =D thx
Modified by SmrCRX at 5:08 PM 7/9/2006
Modified by SmrCRX at 5:09 PM 7/9/2006
evilho75
May 13, 2012 01:35 PM
crdcz03
Jun 21, 2005 08:16 PM
