H22 Swap???
Old Jul 9, 2006 | 08:35 AM
EkPudge's Avatar
Default H22 Swap???
Im currently planning on putting a h22 in my 1993 integra...I'm curious on what i will have to swicth to make the swap work..I know ill need custom mounts but what about the axels? Will they work or will have to get custom axels..If anyone has done this can you inform me on everything i will need to do.
Old Jul 9, 2006 | 08:58 AM
H23 Power's Avatar
Default Re: H22 Swap??? (dat*****01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dat*****01 &raquo;</TD></TR><TR><TD CLASS="quote">Im currently planning on putting a h22 in my 1993 integra...I'm curious on what i will have to swicth to make the swap work..I know ill need custom mounts but what about the axels? Will they work or will have to get custom axels..If anyone has done this can you inform me on everything i will need to do.</TD></TR></TABLE>
the axles are usually determined by the mount kit you will be using.
check the hybrid forum.
Old Jul 9, 2006 | 10:45 AM
DC2 Mang's Avatar
explicitspeed360 sells a mount kit that will allow you to use your stock axles
other than that you have to modify your tranny to use a cable style pull and wire the EGR valves and other misc things
other than that, the car will be pretty damn fast
Old Jul 9, 2006 | 03:59 PM
chaotic_mindz's Avatar
Default Re: H22 Swap??? (DC2 Mang)
yeah pretty much what dc2 said i what you will need i used to have a built h22 in my 4door teg it was pretty quick it ran mid 12's on street tires till i spun a bearing
Rammy
Jan 16, 2008 10:12 PM
integ9505
Jan 13, 2006 03:22 PM
romanG2
Apr 22, 2004 12:15 PM
si foo
Jun 27, 2003 03:15 PM
LilSilver
Jul 30, 2002 02:24 PM
